Low mileage MINI purchase question
Old Mar 10, 2014 | 09:33 AM
9krpm's Avatar
9krpm
Looking at a very low mileage R53 driven about 1K miles per year. Current owner has owned the car for 2.5 years and has done nothing to it.
Is it ok for oil and coolant to sit for that long without being used?
Old Mar 10, 2014 | 09:43 AM
ZippyNH's Avatar
ZippyNH
I would flush the CRAP out of the cooling system.....
Oil....likely ok,,,,but a couple oil changes in quick succession should be fine IMO...sure a bit of surface corrosion MIGHT have occurred during the sitting...that would be scuffed off when stated....that's why I suggest a couple oil changes..
then do a brake fluid flush.....
You do not list an region/location.....
IMO if it was in a cooler area...better...corrosion slows down in the cold....
that is why AN unheated dry GARAGE IS BETTER THAN A HEATED one for storage IMO.
Old Mar 10, 2014 | 09:46 AM
ZippyNH's Avatar
ZippyNH
PS
I would check the cabin filter....when a car sits...mice/rodents can move in....
and look for chewed wired under the hood...same issue.
Old Mar 10, 2014 | 10:43 AM
9krpm's Avatar
9krpm
Car is located in s. cali.
Thanks for your input.
Alkaidovich
Jan 30, 2021 01:35 AM
arf88
May 31, 2016 03:07 PM
phrza81
Oct 10, 2015 11:37 PM
Mini'mon
Aug 16, 2015 04:15 PM
papawhiskey
Aug 10, 2015 09:31 PM
