Mini/bmw antifreeze
Old Oct 27, 2013 | 06:25 AM
joey.k's Avatar
joey.k
Mini/bmw antifreeze
Hey guys
I bought an oem bmw antifreeze from local store, they said it the same as Mini.
It's 1500 ml bottle and says free from nitrite but not mention about phosphates. So is it same and safe to use on my mini coupe S ?
Thank you
Old Oct 27, 2013 | 07:13 AM
ZippyNH's Avatar
ZippyNH
If it says BMW and it is OEM, should be the same stuff....in the US anyway..it is sold in 1 gallon jugs, undiluted....other local areas may vary!!
I buy it at my local BMW dealer...cheaper than at the mini dealer?! Go figure!!
Key is...make sure it is BMW/mini, and not just "compatible" or equivalent... The OEM is blue...use other stuff at your own risk...many do..some do OK...some get flamed... Lol...
Old Oct 27, 2013 | 07:32 AM
joey.k's Avatar
joey.k
Originally Posted by ZippyNH
If it says BMW and it is OEM, should be the same stuff....in the US anyway..it is sold in 1 gallon jugs, undiluted....other local areas may vary!! I buy it at my local BMW dealer...cheaper than at the mini dealer?! Go figure!! Key is...make sure it is BMW/mini, and not just "compatible" or equivalent... The OEM is blue...use other stuff at your own risk...many do..some do OK...some get flamed... Lol...
Thank for the ans but could i trouble you with more question please ?
When i bought coolant i told the sale im gonna use it for my Mini and he didnt ask for model or anything so im kind of confused if this coolant is for old model or new model since i have seen many long life or year round fluid from Bmw. So does bmw oem coolant have one kind of model or else ?
Ps. The label does say anything about year round things, and i meant literally local shop not dealer
Old Oct 27, 2013 | 07:44 AM
ZippyNH's Avatar
ZippyNH
In the US the BMW/mini coolant is blue...and undiluted... You mix it with distilled water to a 50%-50% or 60-40% mix based upon the directions on the bottle....
All specs are on the bottle... Freeze, boil over, etc....Should be self explanatory...
Not sure what you bought....or where you are at...can just speaking from us experience and products from BMW/mini USA........
Old Oct 27, 2013 | 07:55 AM
danjreed's Avatar
danjreed
As long as:
It meets the same specs as G48 (Factory) BMW coolants.
Then its fine.
that said, I'll never mix anything "universal".. or Zerex branded that claims ok, when its not.
Old Oct 27, 2013 | 08:14 AM
ZippyNH's Avatar
ZippyNH
Sounds like the op got a jug...unmarked? At a local garage...
Guess it comes down to trust...
Assuming they just pumped some into a jug from a bulk drum of some type?
What type?? Premixed??? Nobody but the shop selling bit knows. We sure don't...
Can't answer if the stuff you bought will eat you motor's block, destroy it and void your warrenty or is just bulk BMW fluid...which SHOULD be blue....in Europe/us anyway...
Old Oct 27, 2013 | 08:28 AM
joey.k's Avatar
joey.k
Thank for ans
I live in Thailand and yes it does have bmw marked and all but the label, description, packaging, and part number is not the same as USA stuff. That's why it make me confused.
If u google 83192211191, u will know what im talking.
Old Oct 27, 2013 | 08:50 AM
danjreed's Avatar
danjreed
Originally Posted by joey.k
Thank for ans
You are ok!
That Febi product is a fine replacement of the factory stuff.
Just mix it with 1:1 of distilled water. You will be good.
Old Oct 27, 2013 | 09:00 AM
ZippyNH's Avatar
ZippyNH
Originally Posted by danjreed
You are ok!
+1
Should be fine from what I read too...
Part number is different cause it is an aftermarket equivalent fluid...
Most do not meet the orm spec...that one apparently does.
Old Oct 27, 2013 | 02:16 PM
richardsperry's Avatar
richardsperry
Just to be clear, that part # is a Motorad (motorcycle) part #. It's the same as auto, but in a small bottle.
It's probably best NOT TO MIX WITH DISTILLED WATER. USE FILTERED DRINKING WATER! It's an ionic corrosion thing...
Old Oct 27, 2013 | 02:25 PM
ZippyNH's Avatar
ZippyNH
Wrong 100%
Internet lore....
Use only distilled water....
No salts....or minerals like or drinking water...they are the issue....
Old Oct 27, 2013 | 03:16 PM
richardsperry
The new consensus is that minerals in good filtered drinking water, pose less risk than the free ions from distilled water in aluminum cooling systems. Back when radiators were brass, and heads were steel, galvanic corrosion, deposits, and sludge formation out weighed the ionic problem. In today's mostly aluminum cooling environment, with much better antifreeze formulations, you should use filtered drinking water...
Old Oct 27, 2013 | 03:53 PM
Ian Landesman's Avatar
Ian Landesman
Filtered water sounds like a bad idea. Distilled water only for me.
Old Oct 27, 2013 | 03:59 PM
danjreed's Avatar
danjreed
Sources?
First time I'm hearing this.
Given the chlorine content in my city water I can't see how this can be true.
Old Nov 8, 2013 | 08:18 AM
joey.k's Avatar
joey.k
Thx all of u guys
Just talked to authorized bmw and mini
They said they have only one model of antifreeze
And same stuff for bmw and mini
Kimolaoha
Jul 5, 2023 01:04 PM
air540g
Oct 25, 2017 11:08 AM
theateist
Jul 2, 2017 02:21 PM
marendt428
Feb 25, 2016 07:13 AM
Colt45Magnus
Sep 14, 2015 03:12 AM
