problems after a tune HELP PLEASE !!!
First of all id like to say hello. Im new to NAM. I have an 08 R56 with automatic, AEM intake, 2 1/2" down pipe with a hi-flow cat, second cat deleted, resonator still installed, boost tube muffler delete pipe, and a stepped intercooler (not a helix or wagner but its the exact same dimensions).Made a custom shroud to funnel the air thru he new cooler.The car has a new MAF, Vanos actuator solenoid and vanos actuator. It has passed the smoke test, carbon test and pressure test. Still have the receipt from baltimore mini.The problem is... when i go down the interstate about 15-20 minutes if i touch the throttle to pass a car and the car doesnt kick down but just starts to build boost the car will put the yellow engine on the tach and it goes into limp mode. pull over... clear the code... by the way, theres never a code stored, Take off easy, within 1/4 mile, back to limp mode. Just had a tune and it didnt act like this before the tune. I can say that with all the new parts like the MAF and VANOS parts the intake temps went from and average of 103-115 to average of around 85-93. Step on the throttle and within 5 seconds the car goes into limp mode. cat temps use to be 1200-1700. The engine coolant temp is consistantly 210-223. Is this normal for a factory thermostat? After vanos repairs its still the same. Except now it pulls 5th gear out the back door. Could definately pull better in 6th gear tho. This is accomplished before what i think something is getting effected by being heat soaked. This car just turned 161,000 miles and the intake is extremely clean. Got photos of inside the engine and the throttle body.
WHAT IN THE HECK IS GOING ON !?!? PLEASE GIVE ME A DIRECTION TO GO TO NEXT. IM LOST. Except for taking to a shop that i just found yesterday that can reset the computer to factory. I definately wont have anything good to say about the tuner if thats what i gotta do. I will not say who tuned the car. So dont ask, If its not cured....THEN I WILL![Frown](https://www.northamericanmotoring.com/forums/images/smilies/frown.gif)
![Confused](https://www.northamericanmotoring.com/forums/images/smilies/confused.gif)
![Mad](https://www.northamericanmotoring.com/forums/images/smilies/mad.gif)
The tune was 500 at a shop with no flash tool and i dont have the ability to go back to factory. Also the program is encrypted so i cant have another shop fix it. Called weeks before it was 775 with the flash tool and 3 tunes and i could put it back to factory if i chose. I was garunteed not to have issues with this tune.
i got one more thing to do then,im calling him to work this out if it doesnt work. i dont wanna cry wolf just yet to give to tuner the benefit of the doubt. unfortunately he is well known and highly regarded. thats why im trying everything i can. alittle more support would be nice from him tho.
Can't Didn't get a flash tool. Even after I asked. I'll get thru it. Hopefully he will do what's right and work withe on this matter
just went for a ride and for the first time i stayed out of the boost....COMPLETELY !
drove around town, then went on the interstate. Held the speed between 65-70. Never got in boost. Went into limp mode again about 15 miles up the road. im posting these hings so other people who experience the same issues can et a grip on there cars faster than i am since the two people in co-hoots keep saying "i dont know ". must not like people who are smart enough to do there own work and dont give them an open check book to say here ya go... have at it, make me faster
I'm not sure why you would get a tune....but not the tool to switch tunes...
First step is ALWAYS revert to factory tune...and see if the issue persists.... It is always much easier to trouble shoot an engine issue with the stock tune.....
My only suggestion to the op....check for excessive blow-by..... Quite a few gen2 cars did have piston failures In the skirt area from overally aggressive tunes.....and tuning a motor with lots of miles....might be asking too much from fatigued parts....
Good luck.
Good luck.
Good luck.
Good luck.
Good luck.
Good luck.
I agree rob. This car is only at 13-14 and its the first time it's ever had a tune. All maintenance has been done like clock work according to mfgr. Recommendation. Oil every 3000 using Mobil 1 only. I've been taking pictures of the inside as I've be working on it lately during the goose chase he has me on. When I have all parts/options of repairs done, I will post them all. It's pretty darn clean for the miles.
No 05' I didn't. And that's my real issue here. It's the business end that irritates me. And I'm going to be a thorn in his side. This community, tho it is quite large, it's car specific so in the big picture it's rather small. Why should we stand for this type of behavior. These cars cost to much for us to have vendors offer services, take our money on false promises, then not answer emails or phone calls. If he's that busy he should only take on what he can handle to support when there's issue. Everybody here loves these cars. That's why we chose them.
Man that sucks I hope you can get this settled. Tell him you dont want to go public on the fourm but will if you have to. Mabey it will work. Hope everything works out keep us posted.
Rob I'll send you photos of the plugs before and after and you give me your opinion. Got the lifter galley area, compressor inlet, throttle body and intake ports since I took the intake off out of curiosity after he tried to say it needed a walnut shell cleaning. Wait til you see these.... Keep in mind... It's 161,000. It's the first it's been apart
Got the car running again. Still does the exact same thing. Even after I performed some significant amount of work. Drive the car for a bit, head down the interstate, stay out of boost and try to pass a car and not let the car drop into passing gear.... Boom,,, half engine power light comes on. Tried to contact JAN AT RMW thru emails and by phone, left messages. NOT ONE RETURN EMAIL OR PHONE CALL !! Basically, he takes your money, if you have an issue, OH WELL !! He ignores you. Takes your money and runs. There you have it folks. My experience with RMW. it's not the services provided so much that bothers me, it's the way the business is conducted. No support afterwards. NONE !! And when he hears you have an issue he WILL totally ignore you. FIND A DIFFERENT TUNER TO USE !! If he don't have the time to follow up after he shouldn't take your business in the first place.
I wouldn't let that guy tune my lawn mower...sorry about the issues you're having, but it's nothing new. He's been that way since he started "tooning" MINIs. He doesn't really know what he's doing, but everyone thinks he does.
As for reaching Jan, he's very busy with more important things such as his racing hobbies he does. I know he was down in Ohio recently from what I was told. I wouldn't have him tune my car unless it was my last resort. Just wait on a tune by BMS, they're working on the N18 right now and then they'll work on the N14.
I would tend disagree. The worst tuner out there is ETG. Made the guys car blow up.
Sorry to hear about your experiences OP, I never dealt with Jan, but know of his arrogance and his countless blown motor stories. I would never let that guy touch my MINI.
Didn't you just help setup a tuning day for RMW? I don't understand your stance if that's the case...
![Thumbs Up](https://www.northamericanmotoring.com/forums/images/smilies/thumb-up.gif)
