HELP - - - 2009 Clubman S- Day # 2
Old Apr 7, 2013 | 02:26 PM
spcalan1's Avatar
spcalan1
I bought a 2009 Clubman S yesterday and posted how much I loved it.
Today I was driving with my wife at about 40 mph and the car downshifted so hard, it through us into the dash ( luckily we were buckled ) and the car barked its tires. I thought I might have accidentally hit the paddle shifters and thought nothing of it.
So I loaded the family up and figured we would head out to the mountains for a nice trip in the new car.... half way there.. the car lurches and goes into 'safe mode' and will not shift out of 6th gear.. I pull over and turn the car off and restart with no code, but after 2-3 minutes, it lurches again and will not leave 3rd gear. I had to get it towed home..
So much for Day # 2.....
P0717 is the code it threw...
HELP
Old Apr 12, 2013 | 12:57 PM
bratling's Avatar
bratling
Super Moderator
Any good news from the dealer yet? Here's what that code means:
"P0717 - Input/Turbine Speed Sensor Circuit No Signal"
http://www.helpforcars.net/obd_codes/P0717.html
Possible causes
- Transmission speed sensor circuit is open or shorted.
- Poor transmission speed sensor circuit connection
- Faulty transmission speed sensor Help with this
When is the code detected?
Diagnostic Trouble Code (DTC) P0717 is detected when TCM or ECM receives no signal from the sensor.
Symptoms
- Engine Light ON (or Service Engine Soon Warning Light)
- Possible shifting problems
Old Apr 12, 2013 | 01:17 PM
spcalan1's Avatar
spcalan1
Update. I got it back yesterday and it is running well.
I will have a better update once I get a report of what they fixed/replaced.
Old May 17, 2013 | 02:20 PM
rob47v's Avatar
rob47v
My wifes did the same thing. What happened is that the oil level was a bit low, some of these cubbies use oil so be ware of that. It is an acceptable level per mini. Anyway the car went into safe mode wich will limit your speed and shifts. I checked the oil poured in some to proper level and was all fine after that. And by oil I mean engine oil. The computer in these new car will for the most part keep you from destryoing the car.
09R56
Nov 16, 2022 10:49 AM
matthewbrakeii
May 13, 2021 08:39 AM
WarEagle
R55 :: Clubman Talk (2008+)
May 3, 2019 03:00 AM
Sexual Chocolate
Mar 31, 2019 08:02 PM
jbruns29
Aug 14, 2015 01:46 PM
