Oil Change - Use 0W - 40 ?
Old Mar 22, 2013 | 09:16 AM
RoyalCooper's Avatar
RoyalCooper
I have a case of Mobil1 0W - 40 synthetic oil and was thinking of using it for my next two oil changes on my 2013 R58 Coupe.
Was going to do one change at 1,250 miles (only has 775 miles right now). Then not sure if I should do another before the dealer scheduled one at 10K or wait until 15K and do the next.
But most importantly should I even use the 0W - 40 versus the Mini recommended 5W - 30. I'm in SoCal and the ambient temperature range will probably be 50 to 95 degrees over the next several months.
Any thoughts?
Old Mar 22, 2013 | 09:21 AM
richardsperry's Avatar
richardsperry
The Euro blend M1 is approved by Mini, so go ahead.
I chenged my oil at 1500 miles, then again at 6500. BOth times I sent sample to Blackstone labs for analysis, and have now settled on 7500 mile oil and filter changes.
Old Mar 22, 2013 | 09:52 AM
ra2fanatic's Avatar
ra2fanatic
That's my primary oil for my R56 and I'm also in SoCal
Old Mar 22, 2013 | 10:30 AM
RoyalCooper
So the viscosity difference won't be an issue?
Old Mar 22, 2013 | 11:37 AM
richardsperry
It's approved by MINI, what more do you want?
Old Mar 22, 2013 | 04:53 PM
ocluck's Avatar
ocluck
if you're worry about any issue, y not get the MINI oil. most likely, the prices are the same.
Old Mar 22, 2013 | 05:50 PM
RoyalCooper
Actually the case of oil is in my garage from last year (another car, since sold). So one might say it's free (already paid for at least). I think it was under $7 a quart too.
Old Mar 26, 2013 | 07:31 PM
javelina1's Avatar
javelina1
It meets specs, you'll be fine. It's a good oil.
Old Mar 26, 2013 | 08:29 PM
bmwr606's Avatar
bmwr606
if you are worried about using the m1 0W40 in your mini, ship it to me ... i will dispose it in a safe enviromentally safe manner for you
scott
ps i use it in my cms all4
i alternate the m1 0W40 and m1 15W50 in my p/u truck winter/summer and have used nothing but m1 for 290,000 miles in it
Old Mar 26, 2013 | 08:32 PM
ra2fanatic's Avatar
ra2fanatic
I think amazon still has a deal on 0-w40 still. $50 for a case (6 qts) and $12 rebate or if you buy 2 cases then u can qualify for their $24 rebate return. Great deal in my opinion
Old Mar 26, 2013 | 09:05 PM
Minian's Avatar
Minian
I use the M1 0W40 here in the 100+ summers of Vegas and have no issues what-so-ever.
Having said that, I do change my oil every 5-7k depending on how hard I've been running.
Just tore my engine apart last week. The head was spotless and the surfaces of the pistons took just 10min with starter fluid and a brush. (06 R53 128K)
Old Mar 27, 2013 | 05:10 AM
Gil-galad's Avatar
Gil-galad
The Euro blend M1 0W-40 is all I've ever used. FWIW, I'm on my third MINI and have never experienced any noticeable oil consumption or any other engine-related problem. Like many others, I double the MINI recommended frequency of changes and put a new filter on every time.
Old Mar 27, 2013 | 05:14 PM
javelina1's Avatar
javelina1
I've used both GC 0W-30 and Mobil 1 0W-40, here in Phoenix. Both hold up just fine in the extreme heat. I prefer GC, but both oils meet the ACEA A3/B3 and BMW LL-01 specs. Mobil 1 0W-40 is a great oil!
Kimolaoha
Jul 5, 2023 01:04 PM
woodstudio
Mar 15, 2020 08:28 AM
Colt45Magnus
Jul 14, 2019 06:18 PM
patpatpat
Aug 27, 2015 07:51 AM
HaveATank
Aug 24, 2015 10:26 AM
