2012 Mini S first oil change
Old Oct 3, 2012 | 12:18 PM
larryv's Avatar
larryv
What Syn oil are you using on your mini's. I bought the oem oil filters and will have to do this myself. The nearest Mini dealership is 2 hr away. Thanks
Old Oct 3, 2012 | 12:35 PM
grueinthebox's Avatar
grueinthebox
Owners manual has a list of recommended oils. I use Mobil 1 0w40 myself, just because it's the most readily available of those on the list around here.
Old Oct 3, 2012 | 01:53 PM
myoung's Avatar
myoung
Dealers use MINI Oil which is a blend designed by Castrol Syntec W/MINI name tags. See manual for weights and amount. Much cheeper to DIY!!!
Old Oct 3, 2012 | 03:29 PM
mini on's Avatar
mini on
I use Mobil1 0-40 as well
Old Oct 3, 2012 | 04:46 PM
jcauseyfd's Avatar
jcauseyfd
I have run the MINI branded oil, Royal Purple, Pennzoil, and right now I have some Mobil1. My plan is to go back to the Pennzoil once I hit another regularly oil change.
Old Oct 3, 2012 | 07:31 PM
larryv's Avatar
larryv
Great info. thank you very much.
Old Oct 4, 2012 | 01:10 AM
k_h_d's Avatar
k_h_d
Which pennzoil?
Old Oct 4, 2012 | 04:55 AM
VX crazy's Avatar
VX crazy
I use royal purple 5w30
Old Oct 4, 2012 | 05:10 AM
AM_AUTOS's Avatar
AM_AUTOS
Cooper S - 0-50w Castrol Edge
I have 0-30w Castrol Edge in my JCW (UK)
Old Oct 4, 2012 | 05:27 AM
jcauseyfd's Avatar
jcauseyfd
Originally Posted by k_h_d
Which pennzoil?
Pennzoil Ultra Euro, 5w-40. It is the current oil in their product line that meets the ACEA A3/B3 and BMW LL-01 certifications. Biggest challenge for me is I have to order it online and have it shipped to me as a box of 6 qts.
Old Oct 4, 2012 | 05:32 AM
jkapinos's Avatar
jkapinos
Amsoil 0W-30 SSO
Old Oct 4, 2012 | 06:48 AM
bmwr606's Avatar
bmwr606
personally, i am using mobil1 european formula 0w40 due to it being the most available in my area
BMW Long-life rating LL-01 Approved Synthetic Oils for the US Market,per BMW/Mini websites:
Castrol Syntec European Formula SAE 0W-30
Mobil 1 European Formula SAE 0W-40
Pennzoil Platinum European Formula Ultra SAE 5W-30
Valvoline SynPower SAE 5W-30
other oils I have found that are BMW LL-01 rated (by web and examining oil bottles at the oil store):
Motul 8100 X-cess 5W40
Total QUARTZ 9000 5W-40
Total QUARTZ 9000 ENERGY 0W30
Havoline Synthetic Motor Oil
Kendall GT-1 Full Synthetic Motor Oil, SAE 5W-40
Castrol EDGE with SYNTEC Power Technology 0W-30
Castrol EDGE with SYNTEC Power Technology 5W-40
there may be others
scott
Old Oct 4, 2012 | 07:01 AM
jcauseyfd's Avatar
jcauseyfd
You might note the list from the BMW/MINI websites is out of date due to the oil manufacturers changing their product lines.
E.g.:
Castrol Syntec European Formula SAE 0W-30 has been replaced by Castrol EDGE with SYNTEC Power Technology 0W-30.
Pennzoil Platinum European Formula Ultra SAE 5W-30 has been replaced by the Pennzoil I mentioned earlier in the thread.
To my knowledge, the Mobil1 and Valvoline products are still accurate.
Old Oct 4, 2012 | 07:40 AM
larryv's Avatar
larryv
Off to purchase my oil. The mini takes 4.4 quarts, correct? Thanks
Old Oct 4, 2012 | 08:02 AM
bmwr606's Avatar
bmwr606
i have done 4 oil/filter changes between my cms all4 and my dad's cms all4
i put in 4 quarts
with a new filter and 4 quarts, the oil level is right at the middle of the craven dipstick
neither car has used any oil between changes
scott
Old Oct 4, 2012 | 08:05 AM
RobMuntean's Avatar
RobMuntean
+1
Old Oct 4, 2012 | 10:28 AM
Slave to Felines's Avatar
Slave to Felines
Why do you use 50-weight oil in the car? Most of the oils spec'ed in the owner's manual are 30-weight, with a single 40-weight.
Colt45Magnus
Jul 14, 2019 06:18 PM
R60abq
R60/R61 Stock Problems/Issues
Jun 6, 2017 05:15 PM
tr3y003
Oct 22, 2015 10:48 AM
cjsdad
Aug 11, 2015 08:46 AM
