2012 MINI coolant type
Old Mar 7, 2012 | 09:32 AM
Old chuck's Avatar
Old chuck
While during the first oil change on the 2012 S cabrio, I was moving the coolant tank and a hose clamp was not installed correctly and the coolant sprayed out. Not sure what the type of coolant to put back in. The coolant is blue in color but that could just be colored by MINI. Any suggestions? For any who do the first oil change, check the hose clamps because it makes a mess..
Old Mar 9, 2012 | 04:43 AM
Old chuck's Avatar
Old chuck
Odd that no one posted an answer but found it
Searching several forums, I found that Zerex G 05 appears to be the same or so close that there is no noticeable differenced. Zerex is not as common as Prestone or Peak but with some looking, it is available. Thought I would pass this on because if I needed the info then someone else would as well.....
Cereall
Sep 5, 2019 06:05 PM
theateist
Jul 2, 2017 02:21 PM
R60abq
R60/R61 Stock Problems/Issues
Jun 6, 2017 05:15 PM
cjsdad
Aug 11, 2015 08:46 AM
Gipper
Aug 8, 2015 05:39 AM
