Help - change light bulb
Old Jan 8, 2012 | 03:42 PM
TheSkipster's Avatar
TheSkipster
How do I change the front side marker light bulb in the photo below?
Old Jan 8, 2012 | 09:13 PM
RJKimbell's Avatar
RJKimbell
From realoem.com...looks like the Marker should just pull out, would most likely need a Trim Panel Removal Tool.
Like Like this one, from Griot's Garage...
Old Jan 8, 2012 | 09:40 PM
TheSkipster
Ok only $24.99, so it just pry it out with one of those tools-which tool? I looked in from inside the wheel well and it just looks like the lens has a short rod with ribs on it and it's held in by that. I just don't want to start prying and break them off. Have you or anyone actually done this before?
Old Jan 8, 2012 | 11:47 PM
chaswyck's Avatar
chaswyck
I couldn't resist this - How many MINI owners does it take to change a light bulb? So far, THREE!
Old Jan 9, 2012 | 05:42 AM
TheSkipster
Haha, yeah I deserved that one!
Old Jan 9, 2012 | 05:50 AM
theging's Avatar
theging
You beat me to it.
Old Jan 9, 2012 | 05:56 AM
drsimmons's Avatar
drsimmons
Love it! Love it! Love it! ...... Made my morning.
Old Jan 9, 2012 | 07:39 AM
Slave to Felines's Avatar
Slave to Felines
To the OP: Do you still have the owner's manual for your car? If not, you may be able to download one from miniusa's website.
The owner's manual should cover how to change all of the bulbs in the car.
Old Jan 9, 2012 | 08:55 AM
ammodave's Avatar
ammodave
Is there a prize for the best answer? I checked my 2010 owner's manual and it was no help. It explains the replacement of most of the bulbs but not this one.
My suggestion: Partially remove the inner fender liner to gain access to the back side of the lamp. You can do this by removing the bottom two fasteners and pulling the liner out of the way revealing the back of the lamp. Twist the socket a half turn counter clockwise to remove it and change the bulb. I just tried it on my car in the garage, took five minutes start to finish. Good luck.
Old Jan 9, 2012 | 09:07 AM
Jim Michaels's Avatar
Jim Michaels
Now up to four.
I'm just counting the OP and others actually trying to help, so my post doesn't count.
Old Jan 9, 2012 | 09:33 AM
Kirby11's Avatar
Kirby11
Eleven? One to hold the bulb and ten to move the car?
Looks like Ammodave's got it, but this is much more fun!
Old Jan 12, 2012 | 11:00 AM
TheSkipster
Thanks, I'll give it a try and try to keep it to one!
Old Jan 12, 2012 | 12:29 PM
Jeremy Brooks's Avatar
Jeremy Brooks
See those little posts protruding out the back of the marker in the illustration? I suspect that you will find that those are secured with nuts that thread over the plastic. At least that was the case with my '06 rear markers, which looked a whole lot like the one in the parts diagram. So if it feels like something is holding it in place... maybe something is.
sprp85
Aug 22, 2015 06:16 AM
I_drive_slow
Aug 18, 2015 10:47 AM
AZN Optics
Aug 16, 2015 11:52 PM
FLYM1N1
Aug 16, 2015 01:17 PM
