mini transmission
Old Sep 21, 2011 | 08:40 AM
mini?'s Avatar
mini?
mini transmission
New here and was wondering if someone could help me out .. I want a mini cooper automatic without a cvt transmission... which model years are safe? Also how do I tell for sure if it has a cvt or not? I've been trying to find stuff online but it's unreliable. Thanks
Old Sep 21, 2011 | 10:55 AM
Slave to Felines's Avatar
Slave to Felines
I'm pretty sure that all of the 2nd-gen MINIs (2007+) that do not have six-speed manuals have the conventional automatic transmission. I have read around here that the last few years of the 1st-gen could also be equipped with the conventional auto.
Hopefully someone who knows more will be along shortly to chime in.
Old Sep 21, 2011 | 11:27 AM
ZippyNH's Avatar
ZippyNH
All the S' AUTO'S....so 2005+ on gen 1 cars are conventional....cvt was on just the base cooper gen1 cars.
Old Sep 21, 2011 | 11:43 AM
TimL's Avatar
TimL
Correct. Any 'S' has the Aisin 6-speed torque-converter tranny... as do all auto tranny MINIs from '07+ (I forget how the Gen 1 and Gen 2 convertibles overlap, so take that into account if it matters to you.)
If you want to avoid the CVT, then stay away from base Coopers from '02-'06.
Old Sep 21, 2011 | 04:23 PM
mini?'s Avatar
mini?
Thanks.... One other question... Are the cvts really that bad? Everything I've read said they are horrible but then again people don't post stuff unless there's something wrong usually.
Old Sep 21, 2011 | 06:31 PM
wkp1219's Avatar
wkp1219
I have an '06 MCSa with the Aisin 6-speed. I put in standard shift mode at the track and it takes a beating with no issues. I have a little over 50k miles, I change the so called "lifetime fluid" myself and it's been great.
Old Sep 21, 2011 | 10:52 PM
PatM's Avatar
PatM
I think it would probably be wise to steer clear of the CVT transmission.
Old Sep 21, 2011 | 11:25 PM
dannyhavok's Avatar
dannyhavok
There are probably plenty out there running okay, but when they do grenade, it's a $7000 kick in the ***, and there is generally no repairing, only replacing. Don't buy a CVT, there are better options.
Old Sep 22, 2011 | 05:56 AM
wkp1219's Avatar
wkp1219
Is an LSD the same as a Getrag trans?
I know you can have a Getrag w/LSD.........
Old Sep 22, 2011 | 06:19 AM
SSSSSSSS's Avatar
SSSSSSSS
Coordinator :: M2C2
LSD means limited slip differential which was available, as an option, only on the Getrag 6-speed manual transmission. I believe the LSD option is gone replaced with some electronic magic.
lalroma
20
Apr 2, 2022 06:19 PM
Colt45Magnus
Aug 12, 2015 06:43 AM
ludedude
Aug 10, 2015 07:16 PM
fm.illuminatus
Aug 10, 2015 12:15 AM
