Bad Fuel Mileage
Old Nov 21, 2011 | 04:55 AM
  #26
darthhen's Avatar
darthhen
Originally Posted by RJKimbell
If y'all don't know about www.fuelly.com you should check it out, it will help you see what your actually MPGs are from Fill-up to Fill-up, the OBC DTE and MPG ratings are not at all accurate.
Plus you can see what other MINIacs with your same vehicle(s) are getting as well.
I didn't know about this site. I just checked it out...pretty cool. I'll register.....
Old Nov 21, 2011 | 05:44 AM
  #27
MiamiGuitarMan's Avatar
MiamiGuitarMan
Originally Posted by cartpix
Here's an update. Last week my car started running rough & missing at lower RPMs, cleaned up some above 2500 - 3000 range but still surged, & the yellow engine light came on. I took it to the dealer & they gave me a loaner Mini convertible. On the trip home (I zeroed the MPG), the loner showed 26+ MPG as I pulled into my driveway.
My car had a defective spark plug. When I got it back, I took the same route back, hit the traffic lights about the same, about the same amount of traffic, 26 MPG!
What I got out of this is, if it doesn't throw an error code, there's nothing wrong with it & they'll just lie to you, tell you normal, & the mileage is calculated on a closed course with a professional driver. I haven't seen that SA there since & I go just about every week to get it washed.
Call me jaded and cynical but over the years I've become convinced that mechanics at dealerships generally either don't know what they're doing or are just too lazy to do any real mechanicing. Back in the day, if you told them there was a problem with the car they'd get under the hood and try to figure out what it was. Nowadays if you tell them there's a problem, if there's no check engine light or the computer doesn't throw a code they will simply tell you that nothing's wrong and won't even bother to try to figure it out. And it's even worse if the problem is related to mileage or something else they can avoid diagnosing by simply claiming "Oh..well...that varies and it's within spec so there's nothing we can do..."
I've had many issues like this with my last couple of cars. It's frustrating as hell. Nothing as frustrating as knowing that there is a problem and having an incompetent or lazy dealer tell you that it's normal and all in your head because the car's computer didn't throw a code.
Colt45Magnus
Aug 27, 2024 05:03 AM
MasterShaftner
Sep 4, 2015 03:52 PM
Sep 2, 2015 09:05 AM
David.R53
Sep 1, 2015 06:49 PM
DWooderson
Aug 20, 2015 04:31 AM
