Best way to launch the car?
Old Nov 5, 2010 | 09:50 AM
Acesup1090's Avatar
Acesup1090
Hey guys, I drive a 2010 MCS. I've been trying to experiment with launching the car, but still haven't seemed to find the sweet spot. I always seem to have way too much tire spin and then I have to feather it until I catch some traction. I'm still on the original run flat tires, which I despise, but can't afford a solid set at this time. Anyone have a good method to really hard launch the car?
Old Nov 5, 2010 | 01:12 PM
Maugre's Avatar
Maugre
400 lbs. of trinitrotoluene .
Old Nov 6, 2010 | 11:53 AM
trwxxa's Avatar
trwxxa
Nah...
Just a couple hundred pounds of aluminized ammonium perchlorate.
http://www.stupidvideos.com/video/stunts/flyyyyyyyy/
Old Nov 6, 2010 | 12:55 PM
Porthos's Avatar
Porthos
Just peg it off the rev limiter and pop the clutch and you will be good. But in all seriousness its between 2500 and 3500 rpm is a good launch area.
Old Nov 6, 2010 | 01:17 PM
grueinthebox's Avatar
grueinthebox
Really big trebuchet.
Old Nov 6, 2010 | 03:04 PM
erickvonzipper's Avatar
erickvonzipper
Like this?
Old Nov 6, 2010 | 03:25 PM
Eds not-so-red MINI's Avatar
Eds not-so-red MINI
I would think a couple of packages of rubber bands would be sufficient ...
Old Nov 6, 2010 | 05:45 PM
firenewt's Avatar
firenewt
A roll of duct tape and a case of bottle rockets?
Kevin
Old Nov 6, 2010 | 08:18 PM
IMAMINI's Avatar
IMAMINI
Upgraded flux capacitors and dual second generation warp class engine controllers. Bring the matter-anti-matter mixture up to 80% of critical and engage the flow generators while screaming yyyyyyeeeeeeeeehHaaaaaa !!!!
Old Nov 6, 2010 | 09:04 PM
inimini2007's Avatar
inimini2007
Push-N-Pull Back...let go.
Old Nov 7, 2010 | 07:09 AM
Acesup1090's Avatar
Acesup1090
Lol@most of these responses
Old Nov 7, 2010 | 07:23 AM
DICKS GARAGE R53's Avatar
DICKS GARAGE R53
Look up Tannerite VS Car on YouTube, results are impressive for common farming chemicals, and it will launch your car atleast a quarter mile!
In all reality tho, you are going to need to use all 3 pedals at the same time.
Hold in the clutch, have your right foot on the brake with the right side of it holding the gas pedal to about 4-5K RPM, when you are staged lightly slip the clutch to engauge it, on the last yellow of the tree come totaly off the brake and floor it, use the clutch as a traction controll and thats just about it.
It will take some practice but once you pick it up you wont want to do it any other way.
Old Nov 7, 2010 | 12:22 PM
trwxxa's Avatar
trwxxa
Make sure your DSC is turned off! I forgot once, and it was pretty embarrassing.
I used the handbrake to stage. Didn't need three feet to launch, and it seemed to preload the suspension just about right.
Old Nov 7, 2010 | 02:34 PM
Porthos's Avatar
Porthos
This thread went from some wanting to learn how to drive their MINI to nothing but a flame thread. If that happened to anyone else they would have cried up a storm.
Old Nov 9, 2010 | 01:05 PM
martinb's Avatar
martinb
Why bother? Front wheel drive cars just don't launch very well and straight line accelleration isn't exactly the Mini's strong point. Save your clutch and other components and just get it off the line smoothly and easily and once the clutch is fully engaged, only then floor it. If you need to drag race, get a rear wheel drive car, one where you can change the clutch easily and cheaply.
Old Nov 9, 2010 | 01:12 PM
Mat J Monk's Avatar
Mat J Monk
I've heard of Punkin Chunkin but Mini Chunkin?!?
Old Nov 9, 2010 | 01:57 PM
Acesup1090's Avatar
Acesup1090
I recognize that launching the car is going to wear the clutch, tires, ect. and I am willing to shell out money on these parts due to accelerated wear. I respect your choice not to launch the car, but I value the increased entertainment of driving while launching it more than the money to replace the parts. I don't think it's necessary for other people to tell me what to do and what not to do with regards to my driving style.
Old Nov 9, 2010 | 04:09 PM
martinb's Avatar
martinb
Hey, just a suggestion. Have you priced what replacing the clutch costs and are you aware of the work involved? Just checkin'.
If you still want to launch it and aren't, as you say, concerned with accellerated wear, just experiment.
And yea, getting rid of the run flats and going to sticky rubber will help. Though it will likely make it even harder on the clutch and other components.
Old Nov 9, 2010 | 04:34 PM
Maugre's Avatar
Maugre
Exactly Acesup, have fun, life is too short as it is, good luck.
Old Nov 9, 2010 | 04:37 PM
MINI33342's Avatar
MINI33342
Um......it's called practice.
Old Nov 9, 2010 | 05:14 PM
dannyhavok's Avatar
dannyhavok
Man, OP sure got a lot of flack considering this is an "enthusiast" board, and he's enthusiastically enjoying his car! Personally I treat my clutch like a delicate flower, usually no gas until it's fully engaged and I'm rolling. The guy behind me at a light can suck it, I don't have $3k+ to replace it
Old Nov 10, 2010 | 07:29 AM
DICKS GARAGE R53
Most of the people on these boards think of MINI's and drag racing like oil and water. There are however a few (myself included) that do drag their MINI pretty regularly, and it aint half bad at it.
Just remember if someone tells you that FWD cars cant hook up at the strip that: a Scion TC ran a 6 second quarter this summer FWD and all, and that there are plenty of 12 and 11 second (quarter mile) MINI's out there if you know where to look.
PM me and I will direct you to a performance only, no BS forum that has its fair share of drag racers.
Old Nov 12, 2010 | 11:58 AM
beken's Avatar
beken
Nothing beats practice. Find a straight empty road somewhere and just practice your launches until you are able to repeat the good ones. Do it where it is safe. Once you have it, you never forget.
kurosh
Aug 27, 2015 11:54 AM
elightbo
Aug 17, 2015 01:50 PM
ludedude
Aug 10, 2015 07:16 PM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
PatrikKN
Aug 5, 2015 09:10 PM
