Screwed
Old Nov 2, 2010 | 02:54 PM
Falcon24's Avatar
Falcon24
Screwed
Brand new R56 with run flats. Just went to get something out of the Mini and noticed a nice slotted screw in my left rear tire. Pressure is good. Can I get this fixed or do I need a new tire? Suggestions?
Old Nov 2, 2010 | 03:00 PM
Agarwaen's Avatar
Agarwaen
Tire dealers will tell you need to replace it.
However, if you can find a person to patch it, as long as you didn't drive anywhere with low pressure you are relatively safe. I'd recommend removing the wheel at home and bringing it to be patched, instead of driving on it.
Old Nov 2, 2010 | 03:13 PM
UAL_Kingpin's Avatar
UAL_Kingpin
My friend, Lynn, got a screw on her run-flat at about 7,000 miles. Pepboys and Firestone would not patch it. It would have cost her like $225 for a new run-flat. If you get a screw on another tire before the end of the useful life of the tire, then you have to spend another $225.
She ended up biting the bullet and buying four brand new non-runflats and lifetime alignment at Firestone at about $600 (buy-three-get-one-free). From what I was told, you can repair a non-runflat a maximum of three times before it is unrepairable.
You have think hard and do what is best for you.
Old Nov 2, 2010 | 03:41 PM
mcpeso's Avatar
mcpeso
It depends on where the screw is- sidewall vs. tread, straight in vs. angled. Don't run on it if it is under 20 psi. I had a good experience with this at Americas Tire. Patched it free. No harm done. Good luck.
Old Nov 2, 2010 | 03:55 PM
Falcon24's Avatar
Falcon24
It's right in the middle and appears to be straight in
Old Nov 2, 2010 | 04:05 PM
com3tojo3's Avatar
com3tojo3
Perfect spot for a patch, take it to a local tire center, should not cost more than 10-15 bucks to fix
Old Nov 2, 2010 | 04:56 PM
yetti96's Avatar
yetti96
I had a nail just like that recently but I lost pressure. I drove home and plugged it and moved it to the back and went along my merry way. Tire salesmen will say you need to replace the tire, but if in a normal spot on the tire (middle of tread, not sidewall) it can be repaired just like normal.
Old Nov 2, 2010 | 05:10 PM
Falcon24's Avatar
Falcon24
Thank you all very much! Where else can you get support like this. I'll try to get it patched in the morning. Happy Motoring!
Old Nov 2, 2010 | 06:01 PM
devicemanager's Avatar
devicemanager
Yes, you can patch run flats if the affected area is not on the edge or sidewall and you have less than 50mi on it (meaning after the foreign object mated with your tire). Do a search for Dynaplug on this forum for a lot of positive feedback. I for one carry a Dynaplug kit & a slime kit in my boot. I also have the MINI tire and wheel insurance ($1K) that covers both tire and wheel replacements. You may want to consider adding it to your new MINI as well.
Old Nov 2, 2010 | 07:24 PM
mini on's Avatar
mini on
Bite the bullet and get rid of your runflats.
Old Nov 2, 2010 | 09:44 PM
BensMini's Avatar
BensMini
Sounds like you got the word, PATCH IT!
Old Nov 2, 2010 | 10:08 PM
thirdraildesignlab's Avatar
thirdraildesignlab
That no patching business is bs. As was said. I patched mine several times.
Old Nov 3, 2010 | 05:28 AM
UAL_Kingpin
Good luck running around town trying to find a place willing to patch it while knowing the clock is ticking down.
Old Nov 3, 2010 | 05:41 AM
mtbscott's Avatar
mtbscott
Amen.
Old Nov 3, 2010 | 08:43 AM
Maugre's Avatar
Maugre
If you can't find anyone to patch it, see if they will take the tire off, bring it home, patch it yourself, then get it remounted, it's worth a shot, good luck.
Old Nov 3, 2010 | 08:44 AM
Keyser_Soze's Avatar
Keyser_Soze
Have a tire store put a hot-plug in it... You will never know the difference...
Old Nov 5, 2010 | 04:02 PM
Falcon24's Avatar
Falcon24
Had it patched inside and plugged outside.
Thank you all!
Lex2008
How to
47
Jun 15, 2022 06:18 AM
n0mis
MINI5280
11
Mar 9, 2016 05:04 PM
minimofo
Dec 26, 2015 12:03 PM
Cruzer214
Oct 11, 2015 07:45 AM
Colt45Magnus
Oct 1, 2015 04:08 PM
