Oil Filter Cap
Old Oct 1, 2010 | 03:33 PM
hugh's Avatar
hugh
Oil Filter Cap
Took my '05 S in for an oil change. They were not able to get the oil filter cap off. Penetrating oil did not work. Said because of rust and the fact that the cap is aluminum and expands, this can happen. Ended up needing an entire oil filter housing.
Was told later models now have plactic caps to avoid this problem, but they don't make them for the '05 S.
Has this ever happened to anyone else?
Old Oct 1, 2010 | 03:55 PM
KnottyMan's Avatar
KnottyMan
Dealer change?
Never had any issues with my '03. You need to watch the threads putting it back on and not cross thread due to the fine pitch...
Aluminum doesn't really rust like iron either. Yes it oxidizes, but this sounds like a fishy excuse.
I'd WANT a metal canister. I would suspect a plastic can to not do well in that hot environment.
Old Oct 1, 2010 | 04:24 PM
Crashton's Avatar
Crashton
No way that was rusted. They can be hard to get off at times, but I find it hard to believe they really needed to change out the whole thing. I wonder if they broke it & told you a story. I smell a fish...
Old Oct 1, 2010 | 04:44 PM
MINI33342's Avatar
MINI33342
Yep.....a big fat mackerel
Old Oct 1, 2010 | 06:34 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Where did you take it ?
Old Oct 1, 2010 | 06:58 PM
hugh's Avatar
hugh
shop in nj...does bmws...has good reputation.
Old Oct 1, 2010 | 07:33 PM
KnottyMan's Avatar
KnottyMan
You need a 36mm socket which usually (should) means a 1/2 driver. The space is a little tight so you only get two clicks sometimes, but once you crack the O ring seal, it spins off very easy. Fine thread pitch...
I do mine at home and I warm it up with a brief jaunt but not to freeway driving temp. I'm sure it's no fun to jump right in on a hot engine. I wonder if maybe they were in a hurry and cross threaded putting it back on and don't want to cop to it.
Again, I've never had a hint of 'rust' on mine. Examine the 'bad' part.
Old Oct 4, 2010 | 02:36 PM
ViperGTS's Avatar
ViperGTS
If it is aluminum, it would expand at a different rate than the cast head....That being said, it takes quite a while for aluminum to oxidize and when it does, it generally just discolors and looks tarnished. I think they messed something up and wanted you to pay the price for their mistake.
Maybe they rounded the socket end and couldn't get it off.
I always ask for my old pieces back so I can make sure they were replaced when a shop does work that "just pops up". A lot of shops make extra money by "replacing" unnecessary parts.
Kimolaoha
Jul 5, 2023 01:04 PM
devicemanager
Jun 17, 2016 06:18 PM
danielbrookes_9
Oct 3, 2015 12:51 PM
Chasp
Aug 22, 2015 01:26 PM
Laura Redd Casler
Aug 15, 2015 09:32 PM
