Gas cap warning light
Old Apr 2, 2009 | 12:03 PM
bimmerbud's Avatar
bimmerbud
OK, so first part of the week the gas cap check light has come on, first time I've seen it. Checked the cap and clicked it, light went out, next day light comes on again, checked cap, light out then light comes on again after about 5-10 miles of driving, this has gone on for 5 days. Of course I was at the dealer last weekend (4 hr roundtrip) but this came up this week. This morning clicked the cap before leaving the house and at about the 5 mile mark the light comes on, clicked the cap again and it stayed off for 1/2 mile. By this time I needed gas, so filled it up, clicked cap light went off and about 2 miles later on it goes...but then it mysteriously goes off and stays off. I'm almost possitive it has nothing to do with the cap, so what is causing the damn light to come on?
Any thoughts? what do I need to check?
Thanks in advance!
Old Apr 2, 2009 | 02:03 PM
jabell2r's Avatar
jabell2r
Coordinator :: M2C2
Did the dealer do any work related to the fuel system. If so check around the car for any leaks. Outside of going back to the dealer thats all I can think of.
Old Apr 2, 2009 | 02:15 PM
bimmerbud's Avatar
bimmerbud
The dealer was taking care of rattles and noises and nothing related to gas cap, fuel delivery, etc.
Old Apr 27, 2009 | 05:02 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
My 03' MCS with 72,000 miles just started doing this today. Exactly as you described. Maybe it's just me but it seems like the gas cap twists off easier than usual too. Doesn't take much to break the seal and it seems like it should be a tighter fit.
It was at the dealer last week too but there was no fuel system work done, only had the JCW Sport Brake kit installed..
Old Apr 27, 2009 | 05:26 PM
supertramp's Avatar
supertramp
Haven't had any issues with my gas cap but... my gas door seems to be pushed out a little more than it should be and doesn't sit flush with the side panel. It looks like its not fully closed and sticks out a little. Anyone know how to tighten the gas door for it to sit flush to the body. Thanks and sorry if its a little off topic....
Old Apr 28, 2009 | 03:19 AM
-=gRaY rAvEn=-
Moderator
First check and make sure that the black rubber cap line is not getting in the way of the chrome cover. If that is not the case then check the black barrel pin on right which locks the chrome gas cap door shut see if it is not hanging it up. Maybe it needs some WD40 from grit buildup.
If all that is ok then maybe the bracket for the chrome fuel filler cap door was bent somehow when filling up ? Open chrome fuel cap, it is attached to the arm bracket with one #30 torx screw on . Remove torx screw then cap, see if the bracket needs some tweaking. Shouldn't be much. Re-attach the chrome filler cap door and check alignment....
Old Apr 28, 2009 | 11:13 PM
supertramp's Avatar
supertramp
My mini doesn't have the chrome filler cap... it has an actual body color fuel door.. its an 09 justacooper if that helps...
Old Apr 30, 2009 | 04:42 AM
-=gRaY rAvEn=-
Moderator
Didn't take that close of look at the sig.
Old Apr 30, 2009 | 08:48 PM
supertramp's Avatar
supertramp
its okay! Thanks for the attempt I park in a parking garage with about 3 other minis and my gas door noticeably sticks out more than theirs... I was hoping I could adjust it some how.
Old May 1, 2009 | 02:00 PM
-=gRaY rAvEn=-
Moderator
Not sure if the hinge is adjustable or not. Try going to www.realoem.com and take a look at the schematic for that assembly, Maybe that will give us a clue. It would make sense that there is some sort of way to adjust it.
http://www.realoem.com/bmw/showparts...68&hg=41&fg=25
Maybe the actuator is adjustable, if that is what keeps the door closed ?
mrjolliff
Oct 9, 2015 05:55 AM
JamJam43087
Aug 16, 2015 02:02 PM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
WayMotorWorks
Aug 4, 2015 01:47 PM
