General Discussion Competiting with the new MINI on track or at a SCCA Solo event.
Harness Bars Available
Old Apr 12, 2005 | 12:51 PM
MINIcentric's Avatar
MINIcentric
Due to our proximity to the Beaverun Motorsports Complex we are beginning to stock a limited supply of track items. We have one full roll bar for a non-sunroof MINI and 5 Hardbar Harness Bars, we also plan to stock TeamTech race harnesses. PM me for more information!
Graham
MA at MINI of Pittsburgh
Old Apr 12, 2005 | 02:36 PM
Motoring's Avatar
Motoring
what does the Hardbar Harness bar look like and where does it attach?
Old Apr 12, 2005 | 02:40 PM
Rally@StanceDesign's Avatar
Rally@StanceDesign
Graham
What company made the roll bar? Can i come to you guys to have a roll bar installed? i'm in eastern ohio.
Since you guys are so close to beaverun and are track-oriented, do you plan on coming to the big mini challenge?
Old Apr 12, 2005 | 06:51 PM
MINIcentric
You can see the Hardbar Harness Bar on my website at www.chandler-motorsports.com. Both the prototype in my car and the production version in black powdercoat. It attaches to the B pillars.
Graham
Old Apr 12, 2005 | 06:53 PM
MINIcentric
We can install the roll bar. I'll double check the manufacturer of the one we have. I want to come to the MINI challenge if my schedule works out.
Graham
Old Apr 12, 2005 | 10:50 PM
Motoring's Avatar
Motoring
darn, not stock class autocross legal...
Old Apr 13, 2005 | 12:19 AM
MINIcentric
I don't now if this makes a difference, but the harness bar does not remove the utility of the stock seat belt. It's still there when you need it for the street.
Graham
Old Apr 13, 2005 | 06:33 AM
Motoring's Avatar
Motoring
You can't cut the trim panel to allow for installation.
Old Apr 13, 2005 | 08:13 AM
ghoffman's Avatar
ghoffman
That is might be true for H/S but there alot of people doing other classes and DE days that don't care about $25 plactis B pillar covers.
Old Apr 13, 2005 | 08:24 AM
MINIcentric
Well I don't know the exact rules for H-Stock because I prefer HPDE and that's what this product is really intended for as well as various modified autocross classes and MINI racing. The bar acts as a "B" pillar stiffener and increases the load bearing capability beyond the DOT specs. that the MINI "B" pillar was required to pass. The "B" pillar is one of the strongest places on the car and the Hardbar Harness Bar neatly integrates with that component.
Here's a picture:
The production units we have in stock are powder-coated in Tuxedo Black, this is the prototype installed in my car.
Cutting the trim panel seems minor but rules are rules. BTW can you remove the back seat in H-stock?
Graham
Old Apr 13, 2005 | 08:53 AM
Motoring's Avatar
Motoring
No you can't remove the back seats.
The harness bar looks great, there is just no way to attach it to the b pillar that would be Stock class legal.
One could be designed to attach to the C pillar that would be legal, but it would not have the strength of this one.
Old Apr 13, 2005 | 08:59 AM
MINIcentric
Thanks Keith! Now I'm learning about H-Stock, I guess that's the same as showroom stock.
Graham
Old Apr 13, 2005 | 09:28 AM
Motoring's Avatar
Motoring
Similar, but not quite the same. I think showroom stock still requires a Roll cage. Stock class in Autocross can make some changes, like shocks and front swaybars, that aren't allowed in Showroom stock
Old Apr 13, 2005 | 06:01 PM
A&B-MCS's Avatar
A&B-MCS
Directly from the SCCA 2005 Rules.
13.2.H
Driver restraints as outlined in Section 3.3.1 are allowed. Seats
may not be cut to allow for the installation of alternate seat belts or
harnesses. Passive restraint systems may not be removed. A
horizontal “harness bar” may be used as part of the installation
hardware for allowed driver restraints. It may serve no other
purpose (e.g., structural enhancement).
SCCA also recommends roll cages which require cutting of the trim to install so I wouldn't see this being a violation due to that as it is a safety device and the removed weight is more than made up for by the bar.
Old Apr 13, 2005 | 08:10 PM
Motoring's Avatar
Motoring
The hardbar is not a roll cage, and harness bars are specifically not allowed to enhance the structure. Structural enhancement is mentioned in the description of the hardbar. I don't see how it could be legal.
But it is also unlikely anyone would protest you for it at the local level, but if protested I think you would lose.
Old Apr 14, 2005 | 09:29 AM
MINIcentric
I checked the roll bar and it's an Autopower Race Roll bar and meets SCCA standards. We install roll bars here at the dealership in Pittsburgh.
Graham
Old Apr 14, 2005 | 09:39 AM
andy@ross-tech.com's Avatar
andy@ross-tech.com
Here's a picture:
Graham
Why do the brackets for that bar look like they were designed to withstand tension (the bar being pulled rearward in an accident, like being hit from behind) rather than compression (the bar being pulled forward in an accident, like a frontal crash). It looks like the brackets would be quite strong in the former case, but would buckle in the latter situation.
Old Apr 14, 2005 | 11:08 AM
red rage's Avatar
red rage
Graham,
We meet at BeaveRun, at the dinner Banquet thingy and spoke
Did you contact Norm Budka ???
Phil..RED FURY
Old Apr 15, 2005 | 10:59 AM
ghoffman's Avatar
ghoffman
It was designed and analyzed (NASTRAN) for not only compression buckling but out of plane bending due to beam bending under load. The design load is 6000 lbs and it has large safety margins based on yield (i.e. elastic limit).
Old Apr 15, 2005 | 11:08 AM
andy@ross-tech.com
Wow, thanks for the detailed reply.
Old Apr 15, 2005 | 03:59 PM
ghoffman's Avatar
ghoffman
Thank you for the great question! It is very customary in Aerospace Engineering to ask questions that challenge the designer to define his/her design tradeoffs, assumptions, and challenges.
Old Apr 21, 2005 | 04:30 PM
blackshark's Avatar
blackshark
Solo 2 Harness Bar rules....
At the Solo 2 National event in Ft. Myeres FL early last year, the Hardbar harness bar design was reviewed by the local Tech Inspector and, in his opinion, was acceptable for all stock classes. It may be a regional issue....
On page 226 of the 2005 SCCA National Solo rules book states "A harness bar which attaches only between the upper seat belt mounts on the b-pillar complies with 13.2.H".
FWIW, this is referencing Covettes running in Stock classes.....but you could make the argument.....
Denny
Dennis T. Bauer
Director of Business Operations
Hardbar.net, LLC
mailto:dbauer@hardbar.net
ofc: (978) 726-1554
fax: (978) 256-3703
Old Apr 21, 2005 | 07:13 PM
Mark Hirt's Avatar
Mark Hirt
A Tech Inspector and his opinion will not hold up in the protest shed.
As stated above cutting trim pieces to install a "legal" modification makes it not legal. Last year or the year before a CS Miata or Spyder got bounced for cutting trim panels to install a legal roll bar.
If you want to know for sure submit pictures to the SEB.
Old May 24, 2005 | 04:31 PM
MINIcentric
I think there is a need for the Hardbar Harness Bar among people who track their cars in HPDE. I have one in my car with a TeamTech harness and it's a great piece of equipment for that type of event. I understand some of the concerns for stock class events though.
At my last HPDE I invited my instructor to do a few laps and I sat in the passenger seat with the stock seat belt. There is a huge difference when the G forces build up. I was definitely having to brace in the turns which is tiring.
So if you do HPDE then you might want to consider a Hardbar. I have a limited number for sale at the introductory price of $499.00. If you want to see pictures, they are on my website at www.chandler-motorsports.com.
Filmy
15
Jun 6, 2023 06:27 AM
Filmy
Apr 28, 2019 11:37 AM
atlantaorange
Sep 16, 2015 12:43 PM
MINI-Madness
Sep 11, 2015 11:31 AM
Filmy
Sep 7, 2015 08:27 PM
