General Discussion Competiting with the new MINI on track or at a SCCA Solo event.
Longacre Hot Lap Timer
Old May 30, 2004 | 07:30 AM
kmickey's Avatar
kmickey
I just purchased a hot lap timer. Before I fab my own mounting bracket, just curious if anyone else has a lap timer & where/how they mounted it in their Mini.
www.racerpartswholesale.com/hotlap.htm
Old May 30, 2004 | 07:34 AM
ColoradoMark's Avatar
ColoradoMark
I have one - a different brand. I mounted the in-car sensor to the roll bar using some mirror mounts from Pegasus Autosport. I'll try and post some pics later today.
Old May 30, 2004 | 08:12 AM
ColoradoMark
Here are some pics:
This is for an Intercomp timer. I bought some mirror brackets that are designed to mount to a roll cage. Then I went to ACE hardware and bought a carriage bolt, a couple of urethane washers and a know to mount it to the brackett. My sensor has a slot that is about 1/4" wide running down the length on one side that I but the carriage bolt through to attach it to the bracket.
Bracket
Sensor
Old May 30, 2004 | 08:58 AM
kmickey's Avatar
kmickey
Great! thanks for the pics.
Although I don't have a roll bar/cage yet, gives me an idea to mount on the pass. head rest.
How about the display?
kmickey
Old May 30, 2004 | 12:07 PM
ColoradoMark
Still working on that one - probably shouldn't look at it while driving anyways. Right now it's sitting in the rear cupholder.
_________________
IB/W some mods
Old Dec 26, 2004 | 03:13 PM
Mini_Rich's Avatar
Mini_Rich
Receiver mounting w/o rollbar
I'm trying to figure out how to get my receiver mounted too, and without a rollbar it's going to be interesting.
Anyone come up with a solution? I would hate to reinvent the wheel if not necessary!
Old Dec 28, 2004 | 06:13 PM
kmickey's Avatar
kmickey
I'll take some pics of my setup and post it here a little later.
Basically, I've mounted the display under the switch panel.
The receiver is mounted on my camera mount - which is mounted to the passenger head rest posts. You can see this in my gallery:
https://www.northamericanmotoring.co...sort=1&cat=500
Click on that image and you'll get a very close-up view and you can see the receiver mounted on the "modified" camera tri-pod post
mounted horizontally to the passenger seat.
Whatever you do, don't get distracted with the lap timmer during you lap sessions. It can log up to 60 laps. Review your laps times
after the session and then log it in your note book.
kmickey
Old Dec 28, 2004 | 09:20 PM
Mini_Rich's Avatar
Mini_Rich
Thanks - I thought that might be the answer. I'll look for your extra pics. I think that I've got the same camera mount as you, so this should prove easier than I thought!
gnhovis
Dec 14, 2015 05:31 PM
potterstein
Oct 1, 2015 07:10 AM
AoxoMoxoA
Tires, Wheels, & Brakes
Sep 30, 2015 06:00 AM
Brochacho
Sep 29, 2015 10:24 AM
kevinlhr310
Sep 27, 2015 02:31 PM
