Boost fault code
Old Aug 12, 2014 | 02:24 PM
klipper's Avatar
klipper
Boost fault code
Hi all,
I have a 2009 JCW Clubman and I've been getting a the orange engine light warning. Had my dealer look at it and it's the boost sensor fault code. It's happening at about 5,000 rpm. It's happened 3 times now.
Has anybody had a similar situation or know what could be the problem? I've had a software upgrade but it did not fix the issue.
Thanks.
Old Aug 12, 2014 | 02:47 PM
RobMuntean's Avatar
RobMuntean
It could be anyone's guess. MAF sensor, boost leak, ect.
Old Aug 12, 2014 | 03:42 PM
cerenkov's Avatar
cerenkov
Knowing the actual code might help.
Old Aug 13, 2014 | 11:40 AM
klipper's Avatar
klipper
The fault code is 2885.
Old Aug 13, 2014 | 04:21 PM
cerenkov's Avatar
cerenkov
You have a boost implausibility error.
My guess is that:
1.) You have leak somewhere in the boost pipes.
2.) Wastegate is not functioning properly. Check the vacuum hose attached to it.
3.) Diverter valve not functioning correctly.
Have you read this thread:
https://www.northamericanmotoring.co...de-2885-a.html
Old Aug 18, 2014 | 09:14 PM
klipper's Avatar
klipper
Thanks. I'll read the thread to see if I can figure it out. Seems like a process of elimination.... Until you find it.
Old Sep 16, 2014 | 05:45 PM
Yakatak's Avatar
Yakatak
I accidentally disconnected the vac hose between the wastegate and the vacuum box. That left the wastegate always open and therefore no boost My ecu did not throw a code though...only the half engine symbol.
Steffen.Johnson
71
Jan 26, 2021 09:11 AM
shorenetworks
Nov 4, 2019 06:18 PM
NHcountryman
Sep 6, 2015 11:01 PM
tylewis
Sep 6, 2015 01:07 PM
Sep 2, 2015 11:15 AM
