Rotor spec minimums for 2011 JCW
Brake pad warning light came on and the pads and getting down there now.
I can see the rotors have been worn but it does not look like very much but I need to measure them to be safe. I will be using the same pads so if there is plenty of rotor left I should be fine installing the new pads with out turning the brakes. The brakes have been excellent with no vibrations or signs of warping.
I know MINI rotors are fairly expensive. Anyone know of any after market 2 piece units available for the R56 JCW
Is there a question there? If you're looking for the spec minimum, its stamped on the rotor. It might be cast into the face of the hub, or the latest rotors I've got are stamped around the edge of the hub. Its 20.4mm if I'm remembering right.
20.4mm is correct
There are zimmerman rotors available for the JCW.
Pelican parts have the zimmermans at $67 and the BMW rotors at $159 each
http://www.pelicanparts.com/cgi-bin/...FILTER_928M=ON
aldito2
Nov 25, 2015 09:33 PM
squawSkiBum
Oct 2, 2015 09:21 AM
thebordella
Aug 31, 2015 01:37 PM
