Removed Hood Scoop Honeycomb Insert
Old Jul 22, 2011 | 02:44 PM
Jack$0n's Avatar
Jack$0n
On my new 2011 JCW... I was going to do the dremal mod and cut more holes into my Hood Scoop Insert.
Than my dremal gave out.
It lasted many years of punishment... so I can't complain too much.
But than I thought.. hey just take out the insert and lets see how it looks.
Well i like it. I had to use my daughters black finger nail polish and color the grey/white grommet that connects the scoop to the hood and hangs down..
But soo far I like it.
My question is ... has anyone done this? I'm sure you have.... so how did it work out? Any rain issues? Any other issues?
Will probably try this out for a while and test things..
Thx!
Old Jul 22, 2011 | 02:57 PM
zKryT's Avatar
zKryT
When I had my '04 mini, the hood scoop was open. The look was great, but I did have a lot of problems with leaves getting stuck on the inter-cooler...especially in the fall.
I actually had the option to do it on my '10 cooper a few days ago (replaced the scoop with a CF one) and after much thought I left it in because of those problems I had with the '04. Granted, ours are now turbo-ed so the inter-cooler isn't in that spot, but I have an open filter intake (NM) and thought I'd probably end up with leaves getting stuck on that, or at least building up below it which could be a fire hazard.
I'd love to see pictures of what it looks like off; I didn't latch mine down for fear of breaking it taking it off if i didn't like it. Also let us know how it works out if you do keep it off. If there are no problems, or they're minimal, I may have to reconsider my decision.
Old Jul 22, 2011 | 03:04 PM
Jack$0n's Avatar
Jack$0n
Uploaded quick pic
Old Jul 22, 2011 | 03:06 PM
zKryT's Avatar
zKryT
Wow, that looks awesome! So much better without the grill in there. I hope there aren't any problems with it open; I will definitely take mine out.
Old Jul 22, 2011 | 10:24 PM
onefish2's Avatar
onefish2
M7 Vortex 2 hood scoop...no mesh insert. Been running this about 1.5 years. No problem with rain, snow etc. The engine does get dirty quicker but I have my car detailed twice a year so the engine bay get cleaned often enough.
Old Jul 26, 2011 | 05:18 PM
Performance Angst's Avatar
Performance Angst
Mine is out also. Instead of taking a dremel to it you can just remove the hood scoop from the car then unscrew the honeycomb piece and remove. Then pop the scoop back into the hood. The piece comes out quite easy and if you want to put it back down the road, you can.
Old Jul 27, 2011 | 05:51 AM
yetti96's Avatar
yetti96
I had mine out for about 2 days and it look horrible so I dremeled the holes out and reinstalled. The gap was dirty and even once cleaned it didn't look right.
Old Jul 27, 2011 | 03:11 PM
bluefox280's Avatar
bluefox280
Or there's the available laser-cut full-open honeycomb insert from MiniFini; those are excellent for those who don't want to suck up large bugs or small birds into the engine bay.
- Erik
Old Jul 27, 2011 | 03:33 PM
Performance Angst
What dremel bit did you use. I tried that but couldn't find a bit that produced good results and a clean smooth edge.
Old Jul 27, 2011 | 04:58 PM
Jack$0n's Avatar
Jack$0n
- Erik
I like it ..... will order
Think I'm going to paint it red ...shhhh don't tell anyone
Old Jul 27, 2011 | 06:59 PM
yetti96's Avatar
yetti96
I think it was about 1/8" or 3/16" and it had an aggressive bite, cylindrical shaped. It did leave a rough edge but a small file/rasp cleaned it right up.
Old Jul 27, 2011 | 07:09 PM
tvanhouten's Avatar
tvanhouten
Mini Fini
Just a few weeks ago I installed the Mini Fini stainless grill. I thought about painting it black, but for now just left it the natural stainless steel color an like it more and more the longer I have it.
Old Jul 27, 2011 | 07:26 PM
Jack$0n's Avatar
Jack$0n
Wish they also made a grill for the front bumpers, rear bumper, and side scuttle
hint hint!
Old Jul 28, 2011 | 03:49 AM
AAONMS's Avatar
AAONMS
Had a similar grill-like setup on a previous car.
Instead of a Dremel, used an Exacto knife and heated the blade using a candle.
The hot blade easily cut through the plastic.
The key to ease, following the desired cut, and to safety, was to keep the blade hot.
I paused after nearly every cut to reheat the blade.
I like the Mini-Fini stainless one, but wish it was black.
Oh well, there is always Power Coating!
Old Jul 28, 2011 | 04:00 AM
Aether's Avatar
Aether
Minifini Black powder-coat insert....
http://www.minifini.com/ShopDetail.aspx?id=64
Old Jul 28, 2011 | 07:29 AM
Laardilla21's Avatar
Laardilla21
I have the MINIfini black powder coated insert. It works great! Also dropped my intake temps on the DDMWorks Street CAI a few degrees. Yes, it does get the engine compartment dirtier quicker, but like onefish, I detail the engine a few times a year, so no worries for me.
-Johnny
Old Jul 28, 2011 | 08:28 AM
AAONMS's Avatar
AAONMS
Sounds like a call to Russell is in my near future
Old Jul 28, 2011 | 11:51 AM
Redbob's Avatar
Redbob
That looks very good, but around here we need a grille of some sort to keep the grasshoppers and other critters out. They'd make a real mess on the engine...
Old Jul 28, 2011 | 04:28 PM
Performance Angst
I really like this product. Now I just need to find the original screws that hold it on.
Old Jul 28, 2011 | 04:33 PM
Jack$0n's Avatar
Jack$0n
Good luck... they are tiny silver screws
If you need a picture ... let me know
Although I won't be home til Friday night
Old Jul 28, 2011 | 04:38 PM
Performance Angst
A pic of the screw might be very helpful. Especially if you can get one of the whole screw from the side. THanks
Old Jul 28, 2011 | 04:43 PM
Jack$0n's Avatar
Jack$0n
If someone doesn't beat me to it.... I will post some pics & measurements Friday evening.
Does that RealOEM site show screws needed? Just an idea?
Old Jul 28, 2011 | 05:56 PM
Performance Angst
Ok, I think I found them. Four philips pan head wood screw style and silver/grey in color and look to be about a #4 in size and 1/2" long.
Old Jul 28, 2011 | 05:58 PM
Jack$0n's Avatar
Jack$0n
Sounds like them
Old Jul 31, 2011 | 08:31 PM
Melangell's Avatar
Melangell
Johnny!! What's up?? Loving my MiniFini Grill Insert!
