Torque Steer elimination retrofit!!!!!
Old Jun 7, 2011 | 01:26 PM
  #76
Augie05's Avatar
Augie05
How does this NM part impact torque steer?
I have seen the claims but don't understand. Can someone explain what this does regarding torque steer?
Old Jun 7, 2011 | 05:50 PM
  #77
Teibito's Avatar
Teibito
Torque Steer
OK, I know it can be a challenge to deal with, but you just need to hold onto the steering wheel with two hands when not shifting.
I've spent lots of time and money mitigating the torque steer and it is at a tolerable level now. The only time it really gets unruly is when bump steer happens. (pot holes, very uneven expansion joints, etc)
I've lowered the car, put front and rear strut tower braces, a 20mm rear sway bar, and one size over non-run flats (summer only, stiff sidewall, very sticky).
The car really handles nicely. My 2009 JCW is a much better car than my old 2003 MCS. But it did take some extra $$$ to get it there.
Old Jun 7, 2011 | 06:57 PM
  #78
Maltese's Avatar
Maltese
So when you step on the gas with your stock setup, the motor shifts around in the engine bay, and causes the force to not be directly put into the wheels. So when you stiffen the bushings with that insert, the motor doesn't rock as much and the force gets translated to the wheels, helping minimize torque steer. I did a similar mod on my old mazda and it made a huge difference, however you will notice more cabin noise and vibration.
Old Jun 14, 2011 | 09:57 AM
  #79
Murph's Avatar
Murph
Originally Posted by peeti
I just got a call from the service manager who contacted Mini directly. 2.41 will not work on my JCW which is a 2010 as it has a different steering controller supposedly. Do i call BS on this? I find it hard to believe that this is the case. Anyone with a JCW 2010 get this to load and work? I really want it, the streets in chicago are f'd up enough to make steering a challenge. Thanks!
P.S. factory JCW, not build-up fwiw.
This is not true (at least not at my dealer--Global Mini in Atlanta) I had the upgrade done on both my 09 Factory JCW and my '10 Factory JCW---it made a significant difference in the driveablity of both cars, particularly under hard acceleration coming out of a turn.
Supertractor3
Apr 7, 2017 11:16 AM
molala
Oct 2, 2015 01:53 PM
Ntety
Sep 2, 2015 08:39 PM
Suspension Products
Sep 2, 2015 10:32 AM
Sep 2, 2015 09:05 AM
