Seafoam--Smoke from Turbo
Old Mar 1, 2010 | 10:36 AM
Yakatak's Avatar
Yakatak
I performed the standard Seafoam treatment for the valves yesterday. Along with the usual neighborhood de-lousing smokescreen from the tailpipes, I also had a significant amount of smoke escaping from around the turbo . I have a heatshield installed so I couldn't see exactly where it was coming from. Anyone else seen this? Obviously a loose gasket or clamp somewhere on the exhaust side.
Old Mar 1, 2010 | 10:52 AM
Gilboyto's Avatar
Gilboyto
Ouch! Has your car seemed slower or not boost as much lately? Thats scary...
Old Mar 1, 2010 | 11:04 AM
Dr Obnxs's Avatar
Dr Obnxs
Smoke from turbo area
equals leaking exhaust. Yank the heat shield and check it out. Really, you've got the car and no one here can look at the parts for you....
Matt
Old Mar 1, 2010 | 01:23 PM
Yakatak's Avatar
Yakatak
The Clubbie runs like a top. Probably would effect performance more if it was on the intake side. I'll get the heatshield off this weekend and track down the leak. Heck, I might even get a little more power with a proper seal .
Old Oct 16, 2010 | 02:36 PM
iwashmycar's Avatar
iwashmycar
Ive got the exact problem.... Im thinking it would be where the flange connects to the turbo. Since its ONLY comming from the right of the heat shield, its gotta be up high. Boost is seemingly lower as well
My guess it where the 3 bolts are on the cut away flangewhere the red on here is.
Old Oct 18, 2010 | 05:55 AM
iwashmycar's Avatar
iwashmycar
Went ahead and made a service appointment for this Wednesday, so I dont have to bother with breaking the O2 sensor, and my knuckles...
might as well milk the warranty since ive only got 4K left
Ill update later
Old Oct 20, 2010 | 09:44 AM
iwashmycar's Avatar
iwashmycar
Well they said it wasnt a leak (without looking)
The MA came up and was like "..something...something...your modifications...why dont we just go talk to the mechanic"
so i did and he said it was normal because, get this, the turbo gets so hot during Seafoaming that it burns off stuff under the shield. Im thinking, "then how is this thick white seafoamy-exhaust getting out of the damned pipes!?"
He did say he got about 12lbs of boost on the test drive which would be correct, though I can still only get 10.5-11...im sure if that affects it it isnt much.
Oh well, time to get my own knuckles bloody
NYMADMINI
Dec 14, 2016 02:33 PM
GAT
Oct 4, 2015 07:27 PM
Oct 1, 2015 12:13 PM
M7Speed
Oct 1, 2015 07:05 AM
EVMini
Sep 28, 2015 10:20 AM
