JCW Brake job DIY
Old Jun 4, 2009 | 05:20 PM
  #26
AutoXCooper.com's Avatar
AutoXCooper.com
^^^ yep that little metal thing, a shim, is not on the CT XP or AX pads to allow for more pad and reduce one more thing to get hot.
Old Nov 15, 2012 | 06:31 AM
  #27
Tu13es's Avatar
Tu13es
Reviving this super old thread!
My JCW is at 50k, and my brakes don't have that touchy goodness they used to, so I'm thinking it's time for a new set of pads. My rears are especially close to needing replacement. As far as I can tell, my rotors seem to be in fine shape.
I'm curious if anyone's found a guide on how to DIY on these brakes. Though this thread has some good info, I am pretty inept when it comes to cars and would be interested in more detail, particularly on the rears. The fronts seem easy enough that I can do those myself.
I've tried to keep my brakes reasonably clean, but I wonder, when swapping front pads should I clean or lube the pistons or anything when swapping pads? What's the best way to do so? Should I do anything else while I'm at it?
Old Nov 15, 2012 | 09:08 AM
  #28
meckonica's Avatar
meckonica
If you hate brake dust as much as I do, thed you need to contact Dave at www.zeckhausenracing.com/ I have been using him since my 2003 BMW for dust (almost) free brake pads.
He has a lot of info and can help you through the technical stuff.
You are going to need a caliper reset tool kit for the rear brakes because the piston needs to be pressed and screwed back into place it's easy to do but without the tool it is a real "*****". I learned the hard way on my 2003.
Ask him about dust free pads.
I only wash my cars now when the paint is dirty as opposed to when the wheels turn black from brake dust.
You will also need new brake wear sensors otherwise you can't reset the computer to show new brakes.
I hope this helps.
Old Nov 16, 2012 | 06:12 AM
  #29
Tu13es's Avatar
Tu13es
Thinking about it, I don't know if I've had my brake fluid flushed yet. It may have been done once under warranty but probably needs to be done again. I think I might just bite the bullet and have a local shop do it so I can make sure everything is up to snuff.
Old Jul 6, 2013 | 01:04 PM
  #30
Performance Angst's Avatar
Performance Angst
Is it correct to assume to rear caliper tool is turned Clockwise to get the piston back down?
Thaks
Originally Posted by RaceTripper
Thanks phlash.
I found that post earlier with the caliper bracket pivoted down, and I looked up the RealOEM parts list this morning. I think I now have a pretty good picture of how this will work. Your comments helped to pull some things together.
As for that tool. I have a HF caliper tool. I assume that should also work. I'll tackle this on Saturday. I'll be adding Carbotech XP8 to the rear and Bobcat 1521 to the front, along with a flush and bleed using ATE SB. In two weeks I'll do it again on the fronts when I install some XP10 for a track weekend.
I'll see about taking pictures and writing up a DIY.
theblackfalcon
Oct 11, 2015 09:49 AM
thebordella
Aug 31, 2015 01:37 PM
damncajun
Aug 17, 2015 08:25 PM
