Dyno Results 09 JCW
Old Jun 5, 2009 | 05:43 PM
  #51
MotorMouth's Avatar
MotorMouth
Originally Posted by richi0207
A/F looks like a sniffer test was done, pretty rich there! At least its always better to run rich than lean. How does it feel when comparing to the S? Does JCW have lots more potential in terms of low-end grunt and top-end?
yep, it was a sniffer. I expect it's actually running richer than it says since the exhaust went through two cats before reaching the sniffer. That just means there's room for more POWah! lol
Hopefully I'll have another tune or two done in the next couple weeks.
Old Jun 8, 2009 | 12:04 AM
  #52
MotorMouth's Avatar
MotorMouth
The tuner made a new revision map for me today. It's definitely a lot stronger than it was. Not sure how long until I get dynoed again.
Old Jun 14, 2009 | 05:35 AM
  #53
orangecrush's Avatar
orangecrush
Got back last night from dyno'ing my JCW. Jan wasn't overly thrilled with the tune (he actually wants to play with it when time permits) but we ended up with 221.1 whp and just shy of 250wtq.
Last minute before I left, I decided to install a hard hotside downtube. It didn't fit correctly so I had to cut it and ended up using the bottom half of an exhaust depot hard tube and the upper half of an Alta tube.
Under hard boost, the two would come apart and upon the second time, we had to just take the car off the dyno because we were running into time issues.
Billy was great at the Auto lab shop, I'm not particularily fond of his dyno print outs. I guess I'm used to another style software, I find it hard to read.
I'm also not happy with the way the power/tq curves are... kind of wierd but Jan says all JCW's do that... I dunno. Anyway, here it is.
Old Jun 14, 2009 | 10:52 AM
  #54
MotorMouth's Avatar
MotorMouth
My dyno shows the same basic shape. I was wondering about mine too but I guess it is normal.
Did they graph your a/f?
I'd be interested in seeing it.
Old Jun 14, 2009 | 11:09 AM
  #55
orangecrush
Yeah, I've checked out a few JCW sheets and they all appear the same. Jan says it's something about the bigger turbo and how it works with the ECM.
Yes, they did but I didn't get a copy. Jan is suppose to email it to me. Like I said, their dyno prints out the graphs wierd, the af is separate and it's hard to read their graphs in general.
My A/F is on the safe side. Like I said in another post, we had the results higher but Jan didn't want to keep it there for reliability.
I'll see if I can get it.
Mark
Old Sep 12, 2009 | 10:50 AM
  #56
Stig One's Avatar
Stig One
Mark
I need help with the colour match on my jcw. My painter is spraying ppg code 850 pw but can not get the match perfect.What brand paint does mini use ?
Old Sep 12, 2009 | 01:10 PM
  #57
orangecrush
Originally Posted by Stig One
Mark
Ya know, if you hadn't asked, I could have whipped it out but it escapes me at the moment.
Regardless, it shouldn't matter the brand. The painter should be mixing up "prime/standard".
Once "prime/standard" is mixed, they should spray a spray-out card and compare it to the paint on the vehicle.
If the color for instance has a red tone, then they should be seeing if their paint company has a variation "redder than prime".
Regardless whether they do or don't have a variance closer to the true color, they should be able to tint the paint.
I'm in Tampa right now, if the shop wouldn't pitch a fit, I'd be glad to come tint for them. I get calls from bodyshops all the time that need something tinted.
Some colors are worse than others. When I mixed up Laser Blue, I used a combination of Diamont, PPG and Glasurit just to make it match.
Not sure but hope that helps.
Mark
Old Sep 12, 2009 | 01:25 PM
  #58
Stig One's Avatar
Stig One
I own the shop. my booth sucks,can i bring the work to you?
Old Sep 13, 2009 | 06:54 AM
  #59
orangecrush
Well, don't I feel like I was preaching to the choir...lol. If ya want, send me up a tow hook cover or something and I'll mix some up for you.
Let me know, I'll be more than happy to do it.
Mark
Old Sep 23, 2009 | 09:37 AM
  #60
flatlander_48's Avatar
flatlander_48
Originally Posted by Ryephile
There is some value in the factory "prep work" [i.e. pistons, higher flow turbo, stronger cylinder head casting] along with the awesome looking Brembo brakes, eLSD, and nice looking stock wheels. If I was looking to build up an R56 for track work, the JCW would probably be my starting platform.
Don't forget the stronger gearbox...
Old Nov 16, 2009 | 07:45 PM
  #61
Stig One's Avatar
Stig One
900 miles on car 220whp 216 wtq ,dos cai ,riss down pipe,forge intercooler without a tune
Old Nov 17, 2009 | 04:55 AM
  #62
orangecrush
Pretty damn strong WHP numbers without a tune.... can't wait to see what it does with a tune.
Are you doing the RMW tune? There is a tuning party in Orlando in December. I'll be there for a few changes.
Mark
Old Nov 17, 2009 | 06:16 AM
  #63
Stig One's Avatar
Stig One
I will be there.most of my parts are still in boxes or in transit from germany.
we should go to rachels after the tune.
Let jan know he can use my dyno if he has not made arrangments already.
Old Nov 17, 2009 | 06:26 AM
  #64
orangecrush
I'll find out but I think he's already got everything set.. I'll send him a PM.
Mark
Old Nov 17, 2009 | 08:20 AM
  #65
uzun's Avatar
uzun
Mark
Mark,
When is this event taking place? I may be interested if it fits my schedule.
Old Nov 17, 2009 | 11:37 AM
  #66
orangecrush
Originally Posted by uzun
Mark,
I believe it's the first of the first weekend, I'm trying to confirm the exact date myself.
I'll find out and post it when I do.
Mark
Old Nov 17, 2009 | 12:54 PM
  #67
Stig One's Avatar
Stig One
mark
ask jan about colder plugs and if porting the maf (removing the grate ) will help with the dimsport tune.
thanks
Old Nov 17, 2009 | 12:58 PM
  #68
Stig One's Avatar
Stig One
Mark
if jan has a dyno lined up it will be at maitland importers(the place ian works at) downtown orlando,bring a gun and leave the rolex at home if it is at ians place
Old Jan 13, 2010 | 03:55 PM
  #69
ralphie's Avatar
ralphie
dont know why this didn't come to me earlier...
does that mean a base mini S with the JCW tune could make more than a stock JCW given that the mini S is underrated and so close to a JCW already??
Old Jan 13, 2010 | 04:10 PM
  #70
JamesHunt's Avatar
JamesHunt
No
Old Jan 13, 2010 | 06:33 PM
  #71
orangecrush
No
Old Jan 13, 2010 | 07:12 PM
  #72
ENGINE 58's Avatar
ENGINE 58
Hahahhhhaa lol
Old Jan 14, 2010 | 07:47 AM
  #73
MotorMouth's Avatar
MotorMouth
as others said no, however, you can take a base S and with an intake, intercooler, and ECU tuning get more power than a stock JCW. Do the exact same mods to both and the JCW will have a bit more power.
Old Jan 14, 2010 | 05:27 PM
  #74
etalj's Avatar
etalj
And a bit more reliability
Old Jan 14, 2010 | 05:30 PM
  #75
JamesHunt's Avatar
JamesHunt
a jcw turbo and map sensor on a cooper s would work real good with a tune
