R56 Headlights alignment
Old May 18, 2007 | 12:43 PM
snobunny's Avatar
snobunny
When I drive my 2007 MCS at night, I noticed that the xenon headlight on the drive side is much lower than the passenger side. It is very obvious when I am driving on freeways which one side is higher than the other. I brought the car back to the EB Mini dealership and they claim that the headlights are aligned properly when they test it in their garage and refuse any adjustment. It's really frustrating as they claim that the only way they can try figure it out is let their mechanic to drive my MCS home at night.
Does anyone have similar problem with their R56?
Old May 18, 2007 | 01:31 PM
4xAAA's Avatar
4xAAA
The driver's side headlight should be aimed lower than the passenger's. That way approaching traffic isn't blinded.
That being said, I have not seen the offending alignment myself so I can't rule out the possibility that the light is completely whacked out.
Old May 18, 2007 | 01:43 PM
djam43's Avatar
djam43
Thats the way Xenons are aimed, so you dont blind oncoming cars.
Old May 18, 2007 | 01:52 PM
snobunny's Avatar
snobunny
Are all Xenons in MCS are like this?
I had a BMW 330 before and the zenon headlights are aimed at the same level. That's why i'm confused!!! Is it supposed to have a difference so obvious?
Old May 18, 2007 | 02:27 PM
dwdyer's Avatar
dwdyer
All should have a similar pattern, but they do vary. There's some diagrams here that might illustrate
http://www.tfhrc.gov/safety/hsis/pubs/04147/methods.htm
And a comparison of a HID (xenon) to Halogen pattern
http://www.carpages.co.uk/news/news-...s_10_11_05.jpg
The driver's side cutoff is more noticable on HID systems.
Old Jun 30, 2011 | 10:30 AM
Emvin15's Avatar
Emvin15
Hey everyone!
I just managed to get a pair of black Xenon headlights and I managed to install it but the passenger side is quite a bit higher than the driver side(pretty much looks like I have my high beam on my passenger side on). Anyone know how to adjust it??
Any info would be great!
Old Jun 30, 2011 | 10:55 AM
highlander709's Avatar
highlander709
My 11 MCS has Adaptive Xenon lights and they are self leveling. You can see them move into proper position when the ignition is turned on. Second best feature of my car after the sunroof.
Old Jun 30, 2011 | 02:17 PM
Emvin15's Avatar
Emvin15
@highlander709
That's with steering as well right?
These are 2010 Versions and They don't have that capability. I was thinking it would level off as well up/down but it doesn't =S
Old Jun 30, 2011 | 08:52 PM
NJ Mini's Avatar
NJ Mini
There is a small hex screw next to each light that you can see when the bonnet is open. It can be turned with a long phillips head screwdriver or hex wrench. One thing you want to keep in mind with the MINI when adjusting headlights for yourself is just how wide each headlight's beam pattern is, relative to how narrow the car is...in other words, sometimes adjusting the light opposite the one you think is low will give you the desired result.
Hope that helps.
Old Jun 30, 2011 | 10:34 PM
Spice Orange JCW's Avatar
Spice Orange JCW
A factory xenon car has sensors on the A arms that keep the lights level. They work based on the angle of the arm. If your car was originally a halogen car you would not have these sensors.
Old Jun 30, 2011 | 11:02 PM
Emvin15's Avatar
Emvin15
Great info! Thanks! @NJ_Mini would you have a picture off hand at all???
@Spice Orange, I changed all of the necessary parts to obtain what I was wanting but it just seems that in the end that the passenger light is quite higher than the Driver Side.
I will double check to see if I can align them myself and if not in the end I'll bring it to the dealer to adjust it for me.
Thanks everyone!
Old Jul 1, 2011 | 09:54 AM
pheatton's Avatar
pheatton
Spice is correct. The xenon lights are leveled off of the sensors on the lower control arms in the front. From my understanding one should not use the leveling screws to adjust the xenons. Most xenon lights do not have any sort of adjustment screws on them.
Old Jul 3, 2011 | 08:29 PM
turtle343's Avatar
turtle343
i notice this too but it is so you don't blind on comming cars. mine is an 07 and it has the self aligning lights. when you turn them on the light seems to point down at the road and the beam quickly points up to the right level.
Old Jul 3, 2011 | 10:25 PM
Emvin15's Avatar
Emvin15
I will keep that in mind!
Just a thought though, while looking at the headlights without turning the car on it seems as if the passenger side headlight is pointing higher in comparison to the driver side! So just adjusting the casing that moves lower should do the trick!
Just the fact that I've never done it before scares me =S
Old Jul 4, 2011 | 12:38 AM
NJ Mini's Avatar
NJ Mini
I'd agree, I wouldn't adjust these unless its necessary. The auto-leveling feature will help level the light, but the light has to have been set to correct specs for it to function properly. Sometimes they are knocked out of spec from an accident, a pothole, or may have never been set properly at the VDC and need to be adjusted. All headlights have a way to adjust the angle of the beam via torx screw, hex screw or otherwise. I've been able to adjust the xenons on prior cars including an VW, Acura, Volvo, Inifniti and this MCS, in addition to other cars with halogens.
To the OP, I'll try and snap a picture if I get a chance tomorrow, provided it's not down-poring here again.
Old Jul 4, 2011 | 12:26 PM
Emvin15's Avatar
Emvin15
Hmmm, interesting. Thanks NJ Mini!
Old Jul 4, 2011 | 08:45 PM
NJ Mini's Avatar
NJ Mini
Here is the photo. Sorry for the lousy camera phone shot. It's the small grey screw (phillips head) behind the light, not the bolt with red markings. Be very careful when turning it, since even a quarter turn will make a big difference in the headlight angle. What I have done is park on a level driveway facing the garage and slowly adjust the lights from there to make sure they're level.
Hope that helps.
Old Jul 4, 2011 | 09:36 PM
Emvin15's Avatar
Emvin15
That Helps a lot!! Thanks NJ! I will be trying that tomorrow to see if it works!! Thanks for the help everyone!!! Much Appreciated!
Old Jul 6, 2011 | 10:08 AM
Emvin15's Avatar
Emvin15
Hey NJ, it seemed to work for one of my headlights but when I tried it on my passenger side it seemed as if it didn't move at all! =S I will be bringing it into my Service at my location to see if they can do something about it!
Thanks NJ for the pic! Much appreciated!
Old Jul 6, 2011 | 10:46 AM
NJ Mini's Avatar
NJ Mini
No worries. Just as an FYI, before you bring it in, you might want to look into adjusting the opposite headlight. I know it sounds weird, but since these cars are so narrow, the beam pattern is quite wide. I had the same problem where I was adjust the driver-side light down a bit, and no matter how much I tried, it still pointed way too high. Turned out I hadn't adjusted the passnger side correctly and that was actually the side that was too high. I'd give it a shot, and if that doesn't work, then take it in.
Old Jul 6, 2011 | 12:27 PM
Emvin15's Avatar
Emvin15
Hey NJ,
I actually did try it on the driver side as well and it adjusted fine! I compared it to my dad's mini and made it pretty much level with his! Unfortunately I still have to bring it in as the pass. side is still fairly high =S But thanks again NJ!
Old Jul 15, 2011 | 03:22 PM
MISTER_Gunnz's Avatar
MISTER_Gunnz
Thanks for the pic/info, NJ! Much appreciated!
Originally Posted by NJ Mini
Attachment 54338
Hope that helps.
Old Jul 25, 2013 | 06:14 PM
minilynnie's Avatar
minilynnie
Hey there! I know this is an old post, but I thought I'd take a chance and ask one more question. When standing in front of the light, which way do I turn the screw? The light is facing too low to the ground and gives no illumination 20 feet beyond the mini. I want to raise the light just a bit to make it easier to see at night. Thanks for any help. Lynn
Old Aug 12, 2013 | 11:31 PM
Emvin15's Avatar
Emvin15
I believe you turn it to the left to raise the beams. Hope that helps!
jaydeeps
Dec 8, 2015 09:13 PM
Bennyboy
Aug 18, 2015 07:28 AM
R53Mom
Aug 17, 2015 01:38 PM
