F55/F56 Brake Pads
Old Aug 13, 2024 | 05:52 AM
Stu-mon's Avatar
Stu-mon
Brake Pads
my '15 F-56 brake pads are getting close. I have replacement pads & F R wires to install. What I want to know is this : Will the little red dash light come on when the pads are beat ? I don't want rotor damage, I watch 'em like a hawk. BUT I don't want to do 'em until they're beat.
Old Aug 13, 2024 | 07:52 AM
I think its like when ~20% the pads are left
Some people shot through them pretty fast. Depends on the driving style
https://www.northamericanmotoring.co...es-last-2.html
Old Aug 14, 2024 | 04:41 AM
Stu-mon's Avatar
Stu-mon
BUT, the Sensor Wires DO work, they will light up in the dash ? or when they DO youre at the point of incurring rotor damage ? why do they have them at all ?
Old Aug 14, 2024 | 06:21 AM
They light up when the rotor rubs the head off and breaks the contact. No rotor damage, just need to be replaced soon.
Its a system that MINI has had since about 2003. Its just a warning system. Most euro cars have it.
Old Aug 14, 2024 | 07:25 AM
Stu-mon's Avatar
Stu-mon
Bein' old man I don't do it myself anymore & they told me at Mini they were rubbin' but I see wear to go through. they're only 5 miles away but.....I'll get it done when it needs it. I bought '15 Signature few years back, previous owner put JCW brakes all the way around (I figure about 35K, I got 49K on) I'm watchin' but I wanna see a red light (w/o rotor damage)
Old Aug 14, 2024 | 10:56 AM
WhatV8's Avatar
WhatV8
You can see from the pic ECS posted, the sensor is hit way before you get close to the backing plate of the pad. Depending on driving style, I would have to feel you have hundreds, upon hundreds of miles before you would make it through the entire pad material. Don't forget that most rotors these days won't even get one turning out of them, they are virtually just as disposable as the pads. I know my OEM rotors were below minimum limit when I replaced the OEM pads. My current Power Stop pads are much more 'rotor friendly' and so my replacement rotors are now on their second set of PS pads, but I don't think they will survive to see the next set of pads based on some recent measurements. It all depends on how you drive, so YMMV.
Old Aug 14, 2024 | 11:06 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Mileage is a useless parameter for brakes, since they are only used while slowing down. Technically, you "could" drive coast to coast without ever touching the brakes, which would cause them to last the life of the car. Alternately, you could drive in stop-n-go traffic every day, and the brakes could last only 5000 miles. Either you rely on the brake sensor system, and at least check them when the service reminder goes off, or you check them every 5-10k miles and replace when worn down within a few millimeters of the backing plate.
Also, replacing rotors at the same time as the pads is cheap insurance, especially when you do the brakes yourself. Get the least expensive, solid, fully rust coated rotors that will fit, paired with a good set of pads. Done.
Old Aug 14, 2024 | 08:22 PM
blue al's Avatar
blue al
I check mine often enough that I tie up the front sensor as it’s one less job to do
when I change the discs but only cos “road car”
the track R59 has the sensors left in as a 1/4 of pad can disappear in an afternoon session on track , the thinner the material gets the less it can handle the heat, the quicker it degrades, so it’s not linear if that makes sense.
Old Aug 15, 2024 | 05:12 AM
Stu-mon's Avatar
Stu-mon
I use tranny alot & am easy on brakes, so I nurse 'em. Got a set of EBC Ceramic pads & Fr. & R sensor wires ready to rip. The Waiting Is The Hardest Part ! I just wanna make sure they (the wear sensors) work ! Looks like I've got enough meat before I hit backing plates regardless of what Mini says. I got flashlight & 2 eyes. I'm guessing rotors aren't like old days when you could turn'em a time or 2.
Old Aug 15, 2024 | 10:56 AM
WhatV8's Avatar
WhatV8
Yep, you can kick back for a while, even once your sensor trips, the light doesn't indicate a 'life threatening' moment for sure. No, rotors these days are made with much less 'meat' on them and are more of a disposable item. Nik hit it on the head with the rotor choice, actually much more simple than complicated.
Old Aug 16, 2024 | 04:53 AM
Stu-mon's Avatar
Stu-mon
The previous owner (JCW brakes) obviously only did Fr. pads one time R. pads not at all. So, I'm lookin' to do same thing (one axle at a time) I got meat on front, I got rear gettin' close. Mini wants $250/axle, so I'm gonna wear 'em out with no rotor damage. My driving style = I got plenty o' time. I'm not the rabid driver I was when I was a kid . I just turned 69 ! With Age Comes Wisdom !
Minnie.the.Moocher
Wheels/Tires/Brakes
14
Jun 18, 2019 10:51 AM
njaremka
Apr 5, 2019 11:37 AM
Tires, Wheels & Brakes
Jul 6, 2015 08:59 AM
Rick-Anderson
Tires, Wheels, & Brakes
Oct 12, 2006 01:16 PM
dcsmd007
Mar 15, 2004 08:37 AM
