F55/F56 cat.less downpipe
Old Jul 18, 2022 | 10:40 AM
Stu-mon's Avatar
Stu-mon
cat.less downpipe
good day, who builds cat.less DPs other than Forge ? I want to contact everybody FAST & get an extension for my Oxygen Sensor Probe. I figure 1" oughta do it. anybody have their website add. ?
Old Jul 19, 2022 | 09:41 AM
TVPostSound's Avatar
TVPostSound
Do you want a new catless downpipes or an O2 extension?
As far as extensions go, just get a park plug anti fouler. $7 Autozone.
Old Jul 19, 2022 | 10:10 AM
Stu-mon's Avatar
Stu-mon
An O2 extension that will fit a F-series Mini. I found one that will fit a R-series & they say it won't fit F-series. I wanna cap it off & let it hang, I wonder if R & F will interchange or different threads ?
Old Jul 19, 2022 | 10:23 AM
Stu-mon's Avatar
Stu-mon
spark plug anti-fouler - right threads ? does it matter ?
Old Jul 19, 2022 | 12:02 PM
TVPostSound
Arent most O2 sensors M18 x 1.5?? Having a brain fart here.
Old Jul 20, 2022 | 03:55 AM
Stu-mon's Avatar
Stu-mon
going to Mini to look at both R & F O2 sensors, I think they're the same. wanna cap it off & leave probe exposed to air. Florida-Free, wire-tie it out of the way.if it pops in your head let me know. they say if you extend it, even with cat.less DP, it won't stop it from setting it off because it's cat.less. that's what happens when you buy a used car, somebody else's headaches. .my B46M = N12, N14, N16, N18 ? I'm 403FORBIDDEN At ECS website, is that website problem ? or me ? wonder if I could find an american cap to just Jam in there. metric 18mm ? would be nice to know. gonna be hard to find M18 cap !
Old Jul 20, 2022 | 12:51 PM
Hello,
We had a website update, Should work now.
Old Jul 21, 2022 | 04:29 AM
Stu-mon's Avatar
Stu-mon
here's the deal, IF & WHEN my O2 sesor goes bad due to cat.less DP - I'll leave sensor in place, cut tube, unplug plug, plug in New Plug, & zip-tie probe up & away where I can see somewhere near firewall. should I ever need a sensor in Cat.less DP, I'll have it right there to re-install. GOZINYA !
Old Jul 22, 2022 | 03:12 PM
MarioKart's Avatar
MarioKart
Vendor
I sell F series Downpipes with a custom bung so the CEL doesn’t trigger
304 Staiess steel
16G
CNC cut flange
TIG welded
also ECU tuning
MarioPalza@gmail.com
Old Jul 23, 2022 | 05:34 AM
Stu-mon's Avatar
Stu-mon
I like, will be in touch.will shoot you message in gmail to swap data. SS & CAT. up my alley, one & done. reply to message so I know you got it. 2015 F-56, 2.0L, 3" Magnaflow SS exhaust w/ some cat.less exh. pipe (no idea who's.) it's also water/methanol inj. so it's gotta be SS. got a monster deal on this ride all hopped up & this is the last bug to work out. (look at my profile)
Old Jul 30, 2022 | 05:15 AM
Stu-mon's Avatar
Stu-mon
Love it ! can't wait to install. when you Hot-Tune your F-56 past JCW Tune Kit & go water/methanol injection +, you need a SS exhaust. having a Magnaflow SS 3" exhaust, I was lacking SS downpipe. NOMO ! BAD TO THE BONE
Old Jul 30, 2022 | 02:50 PM
TVPostSound
Definitely go with MarioKarts "jewelry"!!
Do not remove the upstreamt O2 sensor, that one is critical. The downstream (past cat) is only there to tell the ECU how to respond to the cat's performance.
Old Jul 31, 2022 | 04:56 AM
Stu-mon's Avatar
Stu-mon
MarioKart is the Ace-In-The-Hole ! not going to cap off ANYTHING. that's not a cat, just a flex-connection. the downstream O2 sensor bung is recessed BIG TIME. try to buy a downpipe, then try to buy a SS downpipe. I gaurandamntee you, you'll get one from MarioKart.
chav
Jun 15, 2017 09:52 PM
chav
Jun 7, 2017 10:51 PM
ltjpunk7
Jun 25, 2014 09:07 PM
cerenkov
Dec 22, 2013 03:43 PM
