F55/F56 MINI F56 Digital Display
Old Jun 27, 2020 | 11:46 AM
minicooperjp's Avatar
minicooperjp
Finally got my digital display! Will try to install and code today
Old Jun 27, 2020 | 01:17 PM
Ocramida's Avatar
Ocramida
What year mini do you have?
how much, and where did you buy it from? Thank you
Old Jun 29, 2020 | 07:06 PM
NBCGLX's Avatar
NBCGLX
Does your car have the nav? Does it have the HUD? If just the former, then you need to add a MOST (i.e., fiber optic) connection between the head unit and the instrument cluster. If you have the latter, then the MOST cable is already installed in the car. If you have neither, I believe it's also plug-and-play + coding.
Also, I'm curious which version of the digital instrument cluster your purchased? The GP3 ones seem to be popular, but I'm looking for just the normal Cooper/Cooper S one found on 2021 models with the navigation. Can't get a dealer to give me a part #, and I've tried several.
Old Jun 30, 2020 | 10:11 PM
minicooperjp
@Ocramida I purchased from https://www.original-autoparts.com/ , it was about $540 shipped.
@NBCGLX The one I purchased is the one from the GP3, I have not seen the part # for the normal ones yet. I retrofitted evo into mine and just added the MOST so it worked fine after coding!
Old Jul 1, 2020 | 09:39 AM
u2asian's Avatar
u2asian
Would you have the part number?
Old Jul 1, 2020 | 12:02 PM
ndal's Avatar
ndal
well done J
62105A189D6
Old Jul 1, 2020 | 03:13 PM
u2asian's Avatar
u2asian
ECS shows back ordered no ETA
https://www.ecstuning.com/Mini-2015-...h/62105A189D6/
Old Jul 2, 2020 | 05:13 AM
FactorFPV's Avatar
FactorFPV
Does anyone have experience with these screens and polarized sunglasses? The HUD is almost totally unreadable with polarized lenses, to the point where I'll sometimes wear some free glasses I got from Geico, rather than my nicer but still cheap Shady Rays.
Old Jul 2, 2020 | 02:17 PM
NBCGLX's Avatar
NBCGLX
Which nav is the evo? Is that the latest touchscreen version found in the 2019-up LCI models? My car is an LCI so it has that from the factory. Do you have the part # for the MOST cable you used? Also, how was the coding experience? From what I’ve seen it can be quite the headache (though I suspect on newer models it may be as easy as just adding the 6WB option code to the VO).
Old Jul 4, 2020 | 12:36 PM
minicooperjp
The evo was the Nav system that came with the F60 and F54 from 17-18, before they went to the smallers units. For me it was a bit more of a headache only because my car originally came with the basic radio before they added the visual boost as the base. I do have a feeling that it should be easier for you, have you checked if your Speedo has a MOST going to it already? I purchased that MOST so long ago that I do not remember where I got it, but it looks just like that.
https://www.ebay.com/itm/MOST-fiber-...oAAOSw7e9dHGgQ
Old Jul 4, 2020 | 05:21 PM
NBCGLX's Avatar
NBCGLX
I’ve pulled the instrument cluster before to install a phone mount, and I don’t recall it having a MOST plug attached. I think only cars with the HUD have it.
How was routing the MOST cable? Easy I imagine? How about coding?
Old Jul 4, 2020 | 06:19 PM
Walt's Avatar
Walt
Maybe we are talking different things, but the Nav system in my 2016 F56, is EVO. I remember that distinction back when i was shopping for a map update.
Old Jul 4, 2020 | 06:22 PM
Walt's Avatar
Walt
By coding, is this something that can easily be done with Bimmercode? Or are we talking about adding/installing new code (not just changing a setting)?
Old Jul 4, 2020 | 06:31 PM
Walt's Avatar
Walt
118 deg F ? !
Old Jul 5, 2020 | 04:36 AM
ndal's Avatar
ndal
You have nbt evo ID4. op has ID5. And cannot be coded with bimmercode.
Old Jul 5, 2020 | 05:49 AM
Walt's Avatar
Walt
Old Jul 6, 2020 | 03:07 PM
minicooperjp
118 deg F ? !
Lol it was a very hot night here in Arizona!
Old Jul 6, 2020 | 03:08 PM
minicooperjp
Running MOST is indeed very easy, and the coding is not bad either
Old Jul 8, 2020 | 04:10 AM
NBCGLX's Avatar
NBCGLX
Can you elaborate on the coding changes that are needed? Do you have navigation instructions showing in the new digital cluster?
Old Jul 12, 2020 | 04:20 AM
hunchbackwhale's Avatar
hunchbackwhale
this is helpful to know - we currently don’t have nav or HUD in our car so this leads me to believe it may be a relative simple installation?
if I were to add the 8.8” screen in place of our current 6.5” non touch, would it still be plug and play (+coding)?
thanks in advance!
Old Jul 12, 2020 | 05:50 AM
ASKtheteach's Avatar
ASKtheteach
My 2015 has the basic display (no media package). I wonder what it would take to add the new digital cluster.
Old Jul 12, 2020 | 07:51 AM
bluonyx's Avatar
bluonyx
You didn't happen to take a pic of the back of the new cluster? Just wanted to see exactly what connections are needed.
Old Jul 13, 2020 | 12:11 PM
MartyO22's Avatar
MartyO22
I am going to guess that is the case. I am a pilot and we all wear glasses with non-polarized lenses otherwise we would not be able to see our Electronic Flight Displays. You'll find some very high quality options out there. I, for example, wear glasses from Randolph USA. They also provide sunglasses to the USAF.
As you might expect, my HUD is crystal clear when I wear them.
Hope that help.
Old Aug 26, 2020 | 04:56 PM
danielngho's Avatar
danielngho
Nice! Congrats!
I have a F55 Cooper S, but Do you know if this works for my model? and what kind of programming do I need?
Regards,
Old Aug 26, 2020 | 05:10 PM
pillpusher84's Avatar
pillpusher84
Originally Posted by danielngho
Nice! Congrats!
Regards,
yes, see my post here: https://www.northamericanmotoring.co...ml#post4550660
