F55/F56 MINI F56 Digital Display
Old Nov 24, 2020 | 02:34 AM
  #26
Chiller q's Avatar
Chiller q
QUOTE=NBCGLX;4542599]Does your car have the nav? Does it have the HUD? If just the former, then you need to add a MOST (i.e., fiber optic) connection between the head unit and the instrument cluster. If you have the latter, then the MOST cable is already installed in the car. If you have neither, I believe it's also plug-and-play + coding.
You ve mentioned if we have neither Navigation nor HUD it can still be done. Mine is a 2015 Cooper S with entrynavi-1 and no HUD.
Would like to know if any features will be missing if we do so?
Anybody done such a retrofit on a non-navigation non-HUD car?
thanks
Old Nov 28, 2020 | 05:01 PM
  #27
varma1986's Avatar
varma1986
My 2019 CountryMan F60 has EntryNBT EVO with NO MOST interface, I do not have Navigation or Car Play or HeadUp Display. Can i still be able to retrofit the 6WB Digital cluster?. My Current Instrument Cluster has just one cable at the back. Is the 6WB Possible on my car?. Thanks.
Old Nov 30, 2020 | 07:13 AM
  #28
Walt's Avatar
Walt
The MOST interface is required. The MOST (fiber optic) jack on the head unit has to still be there, even if currently empty/unused. You need to check this for yourself, to be sure. If it is there but simply empty/unused, it is pretty easy to buy a MOST cable, and plug it in.
Old Nov 30, 2020 | 07:31 AM
  #29
varma1986's Avatar
varma1986
Originally Posted by minicooperjp
Finally got my digital display! Will try to install and code today
My HeadUnit has a slot for the Most cable but it is empty of Pins.The Fakra cable itself is empty where these pins supposed to be. Will it work?.
Old Feb 2, 2021 | 07:25 PM
  #30
NBCGLX's Avatar
NBCGLX
If your headunit has the MOST connector on it, then you should be able to get a MOST cable and plug one end of the cable into the headunit, and the other end into the digital cluster.
Old Feb 21, 2021 | 06:19 AM
  #31
Aaron Bishop's Avatar
Aaron Bishop
I have both the HUD and the digital gauges in my 2021 F60, and haven't had any issues with Polarized sunglasses, but its highly dependent on the particular lenses. I have had other lenses that havent worked well with other devices that have had coatings on them.
Old Mar 16, 2021 | 09:35 PM
  #32
msimon.wi's Avatar
msimon.wi
Help!
Hello All - Hit a brick wall and am needing assistance please!
  • 2015 Cooper S Hardtop w/ harmon headunit (larger screen, no tuch, Nav, no hud)
  • esys: 3.33.4
  • PSdzData Lite: 4.28.21 (only download I was able to find, via link the one working link in this thread)
  • I did not have a MOST cable so I ran one from headunit to new kombi
    • verified that the fiber is in fact functioning, can see the light
    • verified the rest of the vehicle is functioning (i.e. headunit, other electronics)
  • following instructions I get all of the way up till step 9 (find KOMBI in ECU tree)
    • Kombi is missing. In fact, my ECU tree only has 15 different folders (noted by the [15] to the right of the tree's title
  • The kombi in its current state threw a whole slew of errors on the center display and is not displaying my mileage/fuel level/anything accurately.
From reading the thread (like 12 times..lol...) I am just trying to include as much info as possible. Any screen shots or other photos can be attached as needed. More than willing to get on the phone/teamviewer with you if you need to see it also. Any help is greatly appreciated!
Old Mar 24, 2021 | 10:05 AM
  #33
coscosto's Avatar
coscosto
Hi all, i am new here, so i don't know if this is already covered.
i own a 2016 JCW with:
NBTevo_E15413A / No HUD
My Digital Display will arrive shortly.
Do i need to order a MOST cable as well?
If so, any good supplier link (preferably in Europe)?
Old Mar 24, 2021 | 10:26 AM
  #34
NBCGLX's Avatar
NBCGLX
Yes, you’ll need the MOST cable to install between the head unit and the digital instrument cluster. I don’t have a source in Europe, but maybe this Amazon link will help you (this is the one I purchased):
https://smile.amazon.com/gp/aw/d/B07...b_b_asin_title
Old Mar 24, 2021 | 11:04 AM
  #35
coscosto's Avatar
coscosto
Thank you very much!
Old Mar 24, 2021 | 01:05 PM
  #36
Originally Posted by u2asian
Looks like we can get it now but come from overseas.
Old Mar 25, 2021 | 03:35 AM
  #37
coscosto's Avatar
coscosto
Does anyone know if other parameters such as Boost Pressure can be displayed on the Digital Cluster?
are there any code strings that could display parameters in addition to those selected options from the Central Display?
Old May 9, 2021 | 12:40 PM
  #38
MINIkiter's Avatar
MINIkiter
  • esys: 3.33.4
Hi all, I have exactly the same problem as Michael wrote above (Kombi not in ECU tree.) Do you know the solution? I expect it's a fairly simple step in E-sys, but I did not want to guess. Thanks if you can lend any pointers.
P.S. The instructions from @pillpusher84 worked perfectly on another car, but that one already had HUD.
Andy.
Old May 9, 2021 | 01:28 PM
  #39
pillpusher84's Avatar
pillpusher84
if your KOMBI isn't showing in the ECU tree, ensure you coded this in your Headunit FIRST and try to read ECU tree again. This should do the trick for you both
Kombi_CIC = high
EXTERNER_MOST = aktiv
EXTERNE_MOST_DIAG = aktiv
Old May 10, 2021 | 10:32 AM
  #40
msimon.wi's Avatar
msimon.wi
Side note.. If anyone wants a steal of a deal on a digital kombi, HMU. I will not be using mine anymore.
Old May 10, 2021 | 11:59 AM
  #41
pillpusher84
Has it been installed in the vehicle yet? If so, it is now married to that VIN, and the EPROMS on these new digital clusters can not be "viriginized" that I'm aware of. Ran into this this issue when trying to flip a used 6WB on my 2017 340i GT. I had always been able to have a local guy in Brooklyn clear the EPROM on previous clusters so they could be re-used in a different vehicle. BMW started using new chips in 2018 which made this a problem that the community hasn't yet solved that I'm aware of.
Old May 15, 2021 | 04:45 AM
  #42
MINIkiter's Avatar
MINIkiter
Kombi_CIC = high
Hi pillpusher, this didn't work for me right away. I believe I wasn't doing a full code of the HU, rather I was only coding the CAFD so it was still not picking up the KOMBI. I got a pro coder on screen who quickly solved it!
Thanks for your advice, but in my case this really needed someone with experience and more knowledge than me!!
Old May 15, 2021 | 06:38 AM
  #43
varma1986's Avatar
varma1986
What is the difference between listing with Part 62105A189C9 & Part 62105A189D6.
The Part 62105A189D6 is apparently in short supply.
Are they both the same/interchangeable?.
Can i use either of them as a Retrofit for my 2018 Petrol MINI Cooper CountryMan F60?.
Thanks.
Old May 15, 2021 | 06:49 AM
  #44
Walt's Avatar
Walt
Just to mention, I get "Video Unavailable" on all three included in your post.
Old May 15, 2021 | 08:36 AM
  #45
varma1986's Avatar
varma1986
I did a little more research and understand that there are many different 6WB Digital speedometers with different product numbers of BMW MINI and each is pre-configured/tuned to a certain model/engine/fuel type of the MINI Cooper.
Apparently the Part# 62105A189C9 is suitable for my "B38 Petrol MINI Cooper CountryMan F60".
Hope the info helps others searching this matter.
If one to buy a model that is not preconfigured to their car, they may end up having to do more tweaks on the coding to get it to suit.
The cheapest place one can get the parts is currently on BMWPARTSWORLDWIDE website.
Old Feb 4, 2023 | 08:12 AM
  #46
siekdude's Avatar
siekdude
Hi there! I'd like to do this install in my F60 Mini Countryman Cooper S 2019 - I have a HUD and NAV.
Can anyone point me in the right direction as to which Kombi I should get?
Also is anyone in Oregon who can help me with programming?
Thanks in advance
Old Feb 4, 2023 | 09:10 AM
  #47
sambir's Avatar
sambir
Thanks in advance
i have the correct model for you in stock. I can ship to usa. Send me a pm so i can mail you an invoice
The Snowman
Navigation and Audio
Dec 2, 2023 11:24 AM
nutsofamily
Oct 20, 2021 05:38 PM
jamez
Oct 7, 2019 08:56 AM
Porthos
Sep 17, 2015 05:01 PM
