F55/F56 Anyone use these LED headlights?
Old Feb 18, 2020 | 05:22 PM
FunToMini's Avatar
FunToMini
I have a non-LED car, but will be upgrading my rear lights to the LED Union Jack lights (the ones that are plug-and-play (not OEM BMW part), so I figured Id look for head lights as well. These look like the newer versions and are for the F55/F56 cars. They actually look pretty good. Anyone here installed these?
https://www.aliexpress.com/item/4000...archweb201603_
Old Aug 5, 2020 | 12:03 PM
NamBot3000's Avatar
NamBot3000
Did you end up trying them?
Old Aug 7, 2020 | 12:37 PM
ASKtheteach's Avatar
ASKtheteach
I literally just installed them on my MINI yesterday. They took two months to arrive from Singapore. No issues installing them, other than the fact that they come with no instructions and there are wiring harnesses that connect to the stock DRL and running light on each side. No splicing of wires is required. Thry connect in lime, and both the DRL ring and the original DRL light up. Figuring that out took me a few minutes. In total, it took about 45 minutes to install the left side one (the first one I did) and 20 minutes to install the right side one. The change in look is amazing and I love them. Super bright compared to the stock halogens.
Old Aug 7, 2020 | 12:44 PM
ASKtheteach
Oh yeah, two more things: First, they are much less expensive if you buy them from the AliExpress app. You should be able to get them for around $729 with the discounts offered. Second, when you pop the bonnet and look at the stock lights, there are rubber gaskets around the lights that seal the headlight openings when the bonnet is closed. These simply snap off and they need to be reused on the new lights.
Old Aug 7, 2020 | 01:05 PM
NamBot3000's Avatar
NamBot3000
Thanks for the update. They look awesome. I'll have to give these a try. Does the wiring harness only fit one way, as in, there is no way to mess it up?
Old Aug 7, 2020 | 03:43 PM
ASKtheteach
Yes. It’s pretty intuitive. Basically, on each side, you remove the DRL connector and bulb, unplug the connector and then plug it into the harness. The DRL bulb plugs into a new connector and then goes back in place where it came from. Same with the parking (position) light. Then, there is one plug on the other end of the harness that connects to the back of the headlight, as well as the factory headlight connector. Each plug is unique and fits only one way.
Old Mar 30, 2021 | 06:24 AM
MINI Duke's Avatar
MINI Duke
any night time pictures or road pics showing how bright they are? I would love to see them thanks!
Old May 14, 2021 | 11:48 AM
liucmini's Avatar
liucmini
considerations after one year? do they still work? problems? do they make enough light? it would be great if you could put a picture of them when they are on! thank u!
Old May 14, 2021 | 12:48 PM
MoldySasuage's Avatar
MoldySasuage
Where are those lights from because i would like to get a pair but i don't know whether they are available in the states because the thread starter gave a link and the website said that its not available in the states. Thanks
Old May 14, 2021 | 02:08 PM
liucmini's Avatar
liucmini
AliExpress mate ,just search led headlight f56
Old May 15, 2021 | 06:20 AM
MoldySasuage
aliexpress is not available in the states aka united states but they are on amazon for 1250
Old Jun 6, 2021 | 05:51 AM
MINI Duke's Avatar
MINI Duke
So I ordered these headlights from AliExpress and I attempted to install it yesterday came to find out that it didnt come with the bulbs and company is advertising 6500k lumen so I ended up returning it. https://www.aliexpress.com/item/3285...2f684c4drwcSMj
When I contacted the company I was told that it need to purchase D2H bulbs. Kind of misleading to be honest. Can someone send the direct link where you ordered the retrofit headlights from? OP link appears to be a dead link. Thank you.
Old Jul 26, 2021 | 09:18 AM
liucmini's Avatar
liucmini
just missing led drl now :)
Here we go!
Old Jul 26, 2021 | 09:22 AM
liucmini's Avatar
liucmini
bought from aliexpress, but u can also find them from the manufacturing company (long ding auto lamp)
https://longdingautolamp.en.alibaba.com/
Old Jul 26, 2021 | 09:27 AM
NamBot3000's Avatar
NamBot3000
Thanks for sharing. How are they so far?
Old Jul 26, 2021 | 09:29 AM
liucmini's Avatar
liucmini
they are great, huge improve from halogen,seems another car!
Old Jul 29, 2021 | 05:35 AM
Juice84's Avatar
Juice84
Can you link the product on their page? When I click Mini they dont have anything.
Old Jul 29, 2021 | 05:38 AM
liucmini's Avatar
liucmini
https://longdingautolamp.en.alibaba....45497463BUDluL
Old Dec 7, 2021 | 06:39 PM
SVRebuilds's Avatar
SVRebuilds
like this for example or is it a flat beam?
Hi
Do these have a LHD beam pattern when shining on a wall or anything? I can't seem to find if there is any LHD or RHD variants none of the sellers have this listed!?
Could u post a photo of the light beam pattern if possible?
Thanks in advance
Old Dec 7, 2021 | 06:40 PM
SVRebuilds's Avatar
SVRebuilds
Hi
Thanks in advance
minicooperjp
Oct 4, 2020 11:56 AM
miniuy
Mar 8, 2019 09:52 AM
Giano
Sep 24, 2015 07:16 AM
byhsu
Jun 26, 2015 09:36 AM
daffodildeb
May 28, 2014 09:15 AM
