F55/F56 Radio Volume at Startup
Old May 9, 2019 | 07:08 PM
Fbfisher's Avatar
Fbfisher
I recall a setting that automatically lowers the radio volume at ignition startup. I shut the feature off, but now I can’t find it to turn it back on. Any help directing me to the setting is much appreciated.
Old May 10, 2019 | 06:28 AM
Mini_Vinnie's Avatar
Mini_Vinnie
Moderator
Funny, Im looking for the exact opposite. I want it to be louder at startup. I think there is a BimmerCode setting you can code. I dont remember anything "stock" unless its a setting in the radio option
Old May 10, 2019 | 07:21 AM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
  1. You can surely code to have car start with volume the same as you left off with on shut down.
  2. With the menus you can set the car to get louder as you go faster, that is adjustable +-.
  3. Don't recall ever seeing something to lower at start up, it will automatically drop to a set point, see 1st option.
I suspect you have done #1.
Old May 11, 2019 | 07:57 AM
USA-RET's Avatar
USA-RET
The only setting I recall is the setting that allows volume to increase as you increase speed. I routinely listen to the songs at a higher volume when I'm in the car alone than with my wife. I just remember to turn the volume down before shutting the car off when I'm parking it. That way the volume is low when wife wants to use it or if we go out together.
Old May 15, 2019 | 10:52 PM
Fbfisher's Avatar
Fbfisher
Just checks BimmerCode, that’s where I guess I saw it. It’s “Maximum Volume at Start-up” and you and set the % of maximum volume. GuessI was looking at coding options when I was having some programming done.
Cheers!
HarleyDS
Aug 17, 2011 09:02 AM
supermini78
Jan 24, 2010 05:57 PM
BritBoy
Oct 29, 2009 11:01 AM
friedduck
Dec 11, 2002 02:24 PM
drstevenj
Aug 27, 2002 01:59 PM
