F55/F56 Forge Hard Intercooler Pipes
Old Dec 11, 2019 | 08:33 PM
  #26
MrGrumpy's Avatar
MrGrumpy
Originally Posted by Yupetc
Good to see you're also lurking in the 3rd gen forum, too, Grumps! Thanks for the great advice. BTW, my 2nd gen with the JCW turbo and RPM stage 2 tune runs great! but I'm trying to phase out and sell my 2nd gens and currently am working on the 3rd gen build. These cars are fun and addicting for tinkering with.
I’m all over the place, ha ha.
Each gen has its pros and cons, but they do seem to be getting a lot better in some ways.
Besides I help friends tinker with all 3 gens, so I have to keep up on all of the threads!
Old Dec 12, 2019 | 07:07 AM
  #27
Yupetc's Avatar
Yupetc
I totally agree, there are distinct pros and cons with each generation leap, and they are generally heading into better overall offering as a package. I realized there's a lot more heat and noise shielding with the F56 vs the R56, this makes it tactful to work with the engine bay. But every part has its unique practical design for multiple purpose. This makes putting it back together more sensible, it's like snapping lego pieces together.
Well, updating everyone here, I finally got the spring clips in position on both sides with the help of sticking some screwdrivers under the spring and just keep it cocked in place. Then I use more screwdrivers (flat head) to pry at the joint to help, that did the trick. I guess my piping got stuck in place tighter than a simple pull can do. Anyways, thanks everyone for the help.
Old Dec 12, 2019 | 07:17 AM
  #28
MrGrumpy's Avatar
MrGrumpy
When El Grunto and I did his fmic, I had a heck of a time releasing the charge pipes the first time. It was a nightmare for an hour or two. Then I kind of figured it out, they are nit-picky, lol. That made doing the hard pipes later much easier.
Old Dec 12, 2019 | 10:57 PM
  #29
El-Grunto's Avatar
El-Grunto
LOL you say that like I actually did something. I just ****ed around with those dumb bumper clips for a couple hours.
Old Dec 13, 2019 | 01:48 AM
  #30
MrGrumpy's Avatar
MrGrumpy
Well.... that IS something! Ha ha
Old Dec 15, 2019 | 09:33 AM
  #31
MikeMJCW's Avatar
MikeMJCW
Is this upgrade worth it, noticeable improvements etc?
Old Dec 15, 2019 | 08:27 PM
  #32
El-Grunto's Avatar
El-Grunto
The intake pipe allows for cool sounds due to the lack of a resonator but the intercooler pipes won't get your butt dyno to notice anything different. I'm sure if you're doing a custom dyno tune you'd be able to squeeze a little more out if you were previously limited by airflow.
Old Dec 16, 2019 | 09:38 AM
  #33
Yupetc's Avatar
Yupetc
You won't get noticeable horsepower improvements, but if you are going to modify the engine for performance at all, I'd say the intercooler is always the first step. Even without modifying planned ahead, the upgraded intercooler will bring you much better cooling efficiency on the charged air. This makes it a strong engine safety mod even if you're just running it in stock form.
Old Mar 23, 2021 | 12:54 PM
  #34
Lucascohen1's Avatar
Lucascohen1
Hard pipes
I just replaced my intercooler however I broke the metal spring clamps that go on the ends of the pipes. are those replaceable anywhere? or did they come with your FORGE pipes? I have all my seals I literally just don't have the clips
Old Mar 23, 2021 | 12:56 PM
  #35
Lucascohen1
Old May 29, 2021 | 04:20 AM
  #36
fastzombie's Avatar
fastzombie
I have found that on the metal clips I focus on getting the square flange tab out of the connector and resting on the flange of the coupler. I know a lot of people work on the two indented spring clip ends. The square spring flange can hang on the coupler tube. If you work it so the square flange can rest on the exterior of the boost connector it is easier to uncouple the pipe. The photo also shows arrows for the seals that you can't forget to reinstall.
nels415
Feb 28, 2019 09:09 PM
kattanah
Aug 16, 2016 03:40 PM
Aaron-W
Nov 12, 2015 03:46 PM
freeskier
Jun 23, 2010 05:52 PM
