Drivetrain Forge intercooler diverted add on
Old Jun 22, 2010 | 01:39 PM
freeskier's Avatar
freeskier
I'm swapping my stock intercooler with a forge unit and need a diverter/ sprayer, any ideas?
Old Jun 22, 2010 | 01:52 PM
JumpingJackFlash's Avatar
JumpingJackFlash
Why don't you weld one on like this: https://www.northamericanmotoring.co...6-post125.html.
Old Jun 22, 2010 | 02:11 PM
freeskier's Avatar
freeskier
That's a great looking piece I just don't think my fabrication skills are on quite that level.
Old Jun 22, 2010 | 03:22 PM
stevecars60's Avatar
stevecars60
^^ This is a good idea. It does have a couple of issues but a very good mod. If you live in a cooler climate, NE, then I'd leave it alone - I've had a Forge onmy car for 4+ years, no real bad heat soak but for heavy traffic in Boston - as long as you can maintain 24+ mph you're good to go.......
Old Jun 22, 2010 | 04:25 PM
MINI33342's Avatar
MINI33342
Better yet, go back to stock and get an Alta or DDM diverter. Proven to work better than aftermarket IC's.
Old Jun 22, 2010 | 07:21 PM
freeskier's Avatar
freeskier
A stock 88k miles ic with an alt a diverter will woke better than a new forge and a new scoop?
Old Jun 22, 2010 | 08:30 PM
MINI33342's Avatar
MINI33342
Yes
lots of data has been put together supporting this very conclusion. Stock IC has the best recovery and lowest pressure drop.
Old Jun 22, 2010 | 09:08 PM
user 7082082's Avatar
user 7082082
I got my Alta without a diverter and just used thick Weatherstripping
Old Jun 23, 2010 | 05:16 AM
stevecars60
Lots of data post #7 pages & pages....
Here in the NE - the Forge will outperform the OE. There is less loss of boost & the TE is quite good for an IC of this size. The GRS & Forge have an inner core design that is more faverable for boost. It is not a simple formula that can be applied to loss of boost - thermal efficiency.
There are 2 long threads on this subject, however I can't seem to find the first of them ( 3 - 4 years ago???). I tested an OE, Alta classic & Forge - put them on a Superflow, bassed on the result the Forge was best.
Arguments have been made about mass - if you have a 3# brick of aluminum or a 6# .10" sheet of aluminum, which mass will cool fastrer???? Surface with a pourpose is the name of the game when it relates to an IC.
That said: The best bang for the buck was an Alta diverter for the OE IC - with ice I would make on a cookie sheet - it would fit perfectly in the Alta diverter & I could re-load from a cooler with 5+ pieces of ice - better yet was a trip to the local S&S to get a cooler full of dry ice.........
Old Jun 23, 2010 | 05:27 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
He's right. And if you want to eliminate heat soak faster, you would be better off with a more aggressive scoop to increase air flow.
I changed to a GP IC, and while running the M7 Extreme Scoop, temps run for 10-12 deg above outdoor temps, and recovery is pretty fast once back on the highway.
Old Jun 23, 2010 | 08:04 AM
JumpingJackFlash
I agree on the scoop. I have the M7 Extreme Scoop as well. After all my research, the only intercooler upgrade I have considered is the GP model. Since I have the IC off my old '02 MCS as a spare, I'm going to send it off to http://www.cradin.com/ to get a thermal coating for $75. Maybe at some point in the future, I will get a shroud welded to it as well.
Old Jun 23, 2010 | 05:36 PM
MINI33342's Avatar
MINI33342
Be careful with the coatings as they can reduce the airflow thru the IC which is much more important than heat dispersion.
Old Jun 23, 2010 | 05:52 PM
freeskier's Avatar
freeskier
I'm leaning tword the forge but now I need somebody to build me sumthingnwith sprayer heads and a diverter on it
patsum
26
May 29, 2021 06:29 PM
rtk90
Aug 29, 2019 09:08 AM
jdinh504
Dec 18, 2016 11:08 AM
OutMotoring
Sep 8, 2015 06:27 AM
M7Speed
Sep 3, 2015 07:48 AM
