F55/F56 Forge Hard Intercooler Pipes
Thank you again @hadjiikong for your help!
New pipes installed:
https://myredmini.com/forge-intercooler-hard-pipes/
Mini_Vinnie (04-01-2019)
looks great!
One thing I would like to add to this post as Mini_Vinnie and I both experienced this issue is on the old pipes you have to grab the four o-rings from inside the connectors and put them onto the new pipes. If you do not do this you are going to have air leaks which will cause the car to throw codes for too much airflow on the MAF sensor. I spoke with Forge and going forward they are going to include this information with the pipes now.
I am sure you can get them from a BMW/Mini dealership but I repurposed them from the stock pipes. They are a special kind of o-ring sadly not one you can get off the shelf.
Guys, for the life of me, I just couldn't get the pipe off any of those connections; especially in trying to get them off the intercooler joints (both hot side and cold). I understand the unspring the clip into release location, but even then, I couldn't get them to separate. Is there a trick or some sort of secret know-how on this?
I used two separate screw drivers to unseat both arms of the spring. I assume that's enough to clear the joint mechanism for me to pull, but still couldn't pull them separate at all. Pain in the butt, it's been 2 weeks since I'm at it, car still sits in the garage with bumper off, waiting on this pipe to separate from intercooler. If I can't get this done, I'll throw down the towels and not do another lick of upgrading to this S I got. It's really irritating working with this car so far. Gen 2 didn't give me this much grief.
I'll keep at it in the oncoming days. It's so weird. Maybe I'm not doing something right with the spring clips. Are those clips completely removable? If so, it's probably best that I completely take them off before I go and try to separate the joints. Thanks a lot for the input. Will update once I reach the next milestone.
I know it's hard to see but the clip slots right in to the hard pipe and holds it in place. I reused the clips and the seals inside the pipes.
Don’t lose the o-rings!
I helped a friend do these on his car and he had an issue and the large one was lost somewhere on the road. Apparently you can source the 3 smaller ones from the dealer, but to replace the larger one, he actually had to purchase a whole new factory replacement charge pipe just for the o-ring..... and irrc it was over $300.
it would be nice if someone started producing replacements or if Forge had a source for them.
Good to see you're also lurking in the 3rd gen forum, too, Grumps! Thanks for the great advice. BTW, my 2nd gen with the JCW turbo and RPM stage 2 tune runs great! but I'm trying to phase out and sell my 2nd gens and currently am working on the 3rd gen build. These cars are fun and addicting for tinkering with.
