F55/F56 DIY JCW tuning kit installation
Old Jun 15, 2021 | 02:13 PM
  #26
J_L's Avatar
J_L
Yes, the early units had crappy bluetooth. Mostly the issue is the flap closes when it gets interference from a phone or watch, etc. Even from other cars around you. I made a hard wire kit, works very well. Instructions here:
https://www.northamericanmotoring.co...aust-flap.html
Old Jun 15, 2021 | 02:18 PM
  #27
joemysterio's Avatar
joemysterio
That's amazing, thank you!!
Old Jul 17, 2021 | 08:51 PM
  #28
MiniFan254's Avatar
MiniFan254
Hi everyone!
I’m new here and just installed the JCW exhaust in my 2014 F56 3-door today. Wired everything up nice and neat and went to start the car to try the valve, but the car immediately gave me a drivetrain warning and would not start (although it turned over fine). Does anyone have any idea what could have gone wrong here? I did disconnect the battery before doing the wiring and I’m worried that was a major mistake. Any ideas or help would be greatly appreciated!
Old Jul 17, 2021 | 08:57 PM
  #29
J_L's Avatar
J_L
Strange. There's no reason to disconnect the battery, but I don't see why it would cause an issue either. Are you sure you got the fuses in the right places?
Old Jul 17, 2021 | 09:53 PM
  #30
MiniFan254's Avatar
MiniFan254
Hi J_L,
Thanks for your reply. At the time I thought it would be a best to disconnect the battery for safety, but I’m definitely regretting it now.
I followed the JCW BWM install guide as well as the guide here on NAM. I installed the fuses as directed in the attached pdf. They’re in slots F59 (black wire) and F74 (red wire).
i did not have any faults or errors appearing before the install so that’s why I think either disconnecting the battery caused the problem, or there’s something going on with the wiring. I’m planning to disconnect the two wires in the fuse box tomorrow and see if that solves the problem.
File Type: pdf
Old Jul 18, 2021 | 12:02 PM
  #31
MiniFan254's Avatar
MiniFan254
Well I disconnected the fuses and still the car pops up the drivetrain warning and turns over just fine but fails to start. I’m not sure what could be causing this and my Mini is my only vehicle.
any more ideas or suggestions would be greatly appreciated.
Old Jul 19, 2021 | 07:28 AM
  #32
MiniFan254's Avatar
MiniFan254
good news! Car is running again and drivetrain issue has disappeared. Taking it to the dealer for the ECU tune so I’ll mention the drivetrain error to then. The new exhaust sounds great, can’t wait to see if it sounds better after the tune.
Old Jul 19, 2021 | 08:57 AM
  #33
J_L's Avatar
J_L
Great! Any idea what the issue was? Maybe disconnecting the battery was it after all?
Old Jun 18, 2023 | 04:42 PM
  #34
f56_2016's Avatar
f56_2016
Battery related
Regarding on JCW tuning kit installation so do we leave the battery hook on or disconnect ? Cos i dont feel like running some error codes after i install the fuses tomorrow heheh thank you all for pictures and advice for the installation
3d914
How to
41
Feb 11, 2025 08:34 AM
Maine Mini S
Sep 8, 2016 05:10 AM
JPR18
Electrical
Aug 6, 2012 11:35 PM
///ACS330Ci
Electrical
54
Dec 12, 2007 04:59 PM
