F55/F56 Squeaky clutch pedal
Old Jun 28, 2018 | 02:58 PM
Conrad_Thomaier's Avatar
Conrad_Thomaier
Manual trans. I'm getting a squeaking sound when depressing the clutch pedal and then when letting it up. The sound seems to be coming from up under the dash where the clutch pedal arm goes. I couldn't see any places to lubricate.
Ideas?
Old Jun 29, 2018 | 03:02 AM
Rockstar B's Avatar
Rockstar B
Some wd40 on my clutch return spring solved my squeaks
Old Jun 29, 2018 | 05:54 AM
Mini_Vinnie's Avatar
Mini_Vinnie
Moderator
Im still amazed the clutch pedal is plastic
Old Jun 29, 2018 | 07:52 AM
ce_npb's Avatar
ce_npb
I just went through this with my 2014 MCS. The squeak was intermittent, but seemed to happen more when the car was warmed up. Annoying as hell. When I had the car in the dealership, I mentioned it and they lubricated it. The squeak came back soon after. The next time, they said they did some other "fixes" that may or may not be related to a TSB (Sorry, don't really recall). Finally, my clutch slave cylinder gave out. It isn't clear if there was any causal relationship, but when they replaced the slave cylinder, the dealership also replaced the clutch pedal assembly at their cost. I guess they were tired of chasing down the root cause of the squeak.
There are other threads on NAM that discuss this. Some have videos that clearly capture that annoying sound.
Good luck!
Edit: link to another thread
https://www.northamericanmotoring.co...ky-clutch.html
Old Jul 1, 2018 | 11:09 AM
lostronin's Avatar
lostronin
Same issue on 2014 F56 MCS. Brought to dealer and lubrication made no change. They are replacing clutch pedal assembly under warranty.
sorsha6
Jun 13, 2019 06:00 AM
el_Zilcho
R60/R61 Stock Problems/Issues
21
Dec 19, 2014 05:57 AM
dhayashi
May 17, 2012 07:30 AM
FlzRider
Sep 13, 2011 08:47 PM
NJ Mini
Oct 27, 2010 09:14 PM
