F55/F56 Bov on the f56
Old May 31, 2018 | 06:49 PM
F56newbie's Avatar
F56newbie
Bov on the f56
has anyone have a clue of where I can get a video or info about installing a universal bov on my F56Mini? I cannot find anything online for this car
Old May 31, 2018 | 06:54 PM
TVPostSound's Avatar
TVPostSound
The car has a waste gate, not BOV.
That would be redundant
Old May 31, 2018 | 06:58 PM
F56newbie's Avatar
F56newbie
Sorry we’re not all pros like you
Old May 31, 2018 | 06:59 PM
TVPostSound
Wow!! I just stated a fact.
Why would you want a BOV along with a waste gate?
Old May 31, 2018 | 07:02 PM
F56newbie's Avatar
F56newbie
I’m just trying to install a blow off valve on my wife’s F56, just a question that can’t seem to get the right answer
Old May 31, 2018 | 07:03 PM
F56newbie's Avatar
F56newbie
Don’t know to much of the mechanics on turbos, all I know is that I would like to install this bov that I bought. I wouldn’t know the difference between the waste gate and a bov unless I see what it is.
Old May 31, 2018 | 07:04 PM
TVPostSound
May I ask why??
F56newbie's Avatar
F56newbie
for sounds
Old May 31, 2018 | 07:05 PM
F56newbie's Avatar
F56newbie
May I ask why??
because I know that I like how the bov sounds
TVPostSound
A waste gate bypasses excess boost pressure through the exhaust.
A BOV does the same, but most vent to the atmosphere.
So no, no one installs BOVs on a B46/48 motor.
Old May 31, 2018 | 07:06 PM
TVPostSound
You don't like the waste gate sound of the MINI?
Use an open muffler, you'll hear more!!
Old May 31, 2018 | 07:07 PM
F56newbie's Avatar
F56newbie
that’s the question I’ve been searching for and that is all I needed to hear, now I can send this bov back to China. Thank you
Old May 31, 2018 | 07:08 PM
charrigan's Avatar
charrigan
A wastegate is completely different from a blow off valve/ diverter valve.
a wastegate diverts exhaust pressure around the turbine wheel to control boost.
a blow off valve/diverter valve is in the cold side/charge pipe of the intake side. Its sole purpose is to divert excess intake pressure to prevent compressor surge. A blow off valve vents that pressure to the atmosphere and a diverter valve recirculates that pressure back into the intake path.
bmw has a history of diverter valves causing boost issues (n54 and n55). In the B series engines they eliminated the need for using diverter valved and they use vanos to open the intake and exhaust valves at the same time to bleed off pressure. When they do this it increases exhaust pressure so the wastegate on the turbo cracks open briefly to prevent boost building.
even on a stock b48 you can induce compressor surge. On a tuned engine due to the increased boost you can hear the compressor surge even more. Based off durability testing they didnt observe the need to add a diverter valve. This also saves them money on production of the engines because of removing components and hoses.
F56newbie's Avatar
F56newbie
I want to hear that psssssss sound. Just personal preference
Old May 31, 2018 | 07:10 PM
F56newbie's Avatar
F56newbie
bmw has a history of diverter valved causing boost issues (n54 and n55). In the B series engines they eliminated the need for using diverter valved and they use vanos to open the intake and exhaust valves at the same time to bleed off pressure. When they do this it increases exhaust pressure so the wastegate on the turbo cracks open briefly to prevent boost building.
so are you recommending an exhaust system? If so, what size piping and is there a good one you recommend?
Old May 31, 2018 | 07:14 PM
charrigan's Avatar
charrigan
not recommending anything. just explaining that a diverter valve and wastegate are have completely different purposes.
if you want the blow off valve sound the closes you will get is to purchase an intake. An exhaust is just going to make your car louder and will not give you the "psssh" sound of a blow off valve
Old May 31, 2018 | 07:16 PM
TVPostSound
The BOV hiss, in my eyes/ears says Honda Civic.
Any straight through muffler will increase the "Vanos" compression dump, and waste gate through the exhaust. That sound to me is more GTR...
Its so cool when the upshift coincides with me passing a Challenger, or Camaro!!
Old May 31, 2018 | 07:19 PM
F56newbie's Avatar
F56newbie
lmao don’t know if you’ll pass up my ram🤣 jk
Old Jun 1, 2018 | 04:24 AM
trentiles's Avatar
trentiles
TVPostSound - all turbos have a wastegates. BMW choose a design that doesn't use a diverter valve or blow off valve. Most other car manufacturers with turbo cars (with wastegates) also use diverter vales.
F56newbie, if you want blow off type sounds just get an open filter intake. It will be plenty loud! An exhaust will not give you the sound you are looking for.
Old Jun 1, 2018 | 05:59 AM
F56newbie's Avatar
F56newbie
Thank you
Old Jun 1, 2018 | 04:14 PM
TVPostSound
The open exhaust, on mine, increases the Vanos Wastegate "Burble"
To me that sound says Turbo more than a BOV.
Old Jun 1, 2018 | 06:16 PM
F56newbie's Avatar
F56newbie
Different show for different folks
Old Jun 14, 2018 | 06:28 PM
Affa114's Avatar
Affa114
Researched long ago, even opened a post here.
Conclusion is you dont need one in terms of performance. If you purely want one for PSSSSSS noise, get universal HKS BOV, find some people to make a custom bracket/adapter, put it in between the charge pipe and intake manifold. It has been done before by few people, at least one posted here, and chinese sells the whole kit through chinese ebay which comes with HKS BOV and the bracket, just not sure if the BOV is genuine HK.
Old Jun 15, 2018 | 04:15 AM
trentiles's Avatar
trentiles
Old Jun 22, 2018 | 02:12 PM
Yes, I have seen people do the noise marker mod, but yes no factory set up so no forge BOV or anything like that.
