F55/F56 2.5L F56 engine, because 2.0L wasn't enough
Old May 3, 2018 | 11:17 AM
Revolution Motor Works's Avatar
Vendor
Many people were asking about making real performance parts for the 3rd gen so I jumped in head first as usual. This is the 1st full sleeved big bore F engine stroker in the world........ Keep your eyes peeled for all of the cool parts coming for this monster of a Mini
custom made ductile iron sleeves capable of 50psi
fresh sleeves and deck, bore and hone yet to complete
Old May 3, 2018 | 02:17 PM
vetsvette's Avatar
vetsvette
Moderator
Just when I thought I had the motor finished......
Now Jan comes up with this. ��
Subscribing to the thread.
Old May 3, 2018 | 08:59 PM
GPMini's Avatar
GPMini
WOW. Cant wait to see what this produces.
Old May 4, 2018 | 03:40 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Oh YEAH!!
Old May 4, 2018 | 04:13 AM
02fanatic's Avatar
02fanatic
You might think of making it all wheel drive to harness all the power you might end up with! More power is not always a good thing if the chassis & drivetrain can’t handle it! Just sayin....sounds delicious though....good luck!
Old May 4, 2018 | 06:13 AM
charrigan's Avatar
charrigan
cant wait to see the build complete!
Old May 5, 2018 | 05:19 PM
camptown's Avatar
camptown
Old May 7, 2018 | 03:52 PM
djtomy's Avatar
djtomy
That's going to be fun!
Old May 7, 2018 | 05:23 PM
Silversled's Avatar
Silversled
Now we are talking!
Old May 7, 2018 | 06:54 PM
cornjuice's Avatar
cornjuice
in b4 '500club'
Old May 8, 2018 | 04:29 PM
AndresR's Avatar
AndresR
Jan,
Any plan to upgrade the torque converter on the 6 speed Auto trans? Or this will be only for manual transmission?
Old May 8, 2018 | 04:33 PM
Vendor
Originally Posted by AndresR
Jan,
I will be checking into some Auto options once we have finished up the manual testing
Old Jan 13, 2020 | 08:14 AM
CarFreak427's Avatar
CarFreak427
Any updates on this?
Old Jan 13, 2020 | 10:40 AM
Yupetc's Avatar
Yupetc
I assume you're modifying the dome volume in the heads, changing out rod length, or crank size with this bore? Because you'll just be running very high compression numbers. By calculation for static compression, you'd need to run 91.7mm piston diameter to get 2499cc and that'll put your compression ratio at 13.2. That's going to be one hell of an engine to tune and work against pre-detonation. You'll probably then need to lower your stroke to about 70mm to get 10.0 compression, or 78mm stroke to get 11.0 compression assuming no change in crank nor doing any head work..
Of course there are various other ways to deal with compression ratio, and the VVT in Twin-Powered features are already in place if you can tinker with valve overlap and timing. Kind of an interesting thread to follow. Subscribed.
Old Jan 13, 2020 | 11:57 AM
ST107's Avatar
ST107
In for updates
Old Jul 27, 2022 | 10:09 PM
CarFreak427
Old Jul 28, 2022 | 10:01 AM
Darbys2019MiniJCW's Avatar
Darbys2019MiniJCW
Is this a 2.0L that has been enlarged?
Old Jul 28, 2022 | 10:53 AM
TVPostSound's Avatar
TVPostSound
Yeah enlarged bore sleeves, notice the water jackets around the sleeves are now much smaller!!
Old Jan 16, 2025 | 08:55 AM
dannieh42's Avatar
dannieh42
What ever became of this project? Did you finish it? Give us an update, please.
Old Jan 16, 2025 | 11:21 AM
Cableaddict's Avatar
Cableaddict
Jan,
The stock 8 speed auto can handle the torque of a GP, so that might be a good fit.
Personally, if I was to use this engine, I'd want a dual clutch with paddles.
jamez
Oct 7, 2019 08:56 AM
Tweedbean
Sep 4, 2015 05:37 PM
clintmeister
Mar 26, 2015 09:22 AM
mkskchun85
May 1, 2014 10:18 AM
borderwave2
Oct 2, 2013 01:20 PM
