F55/F56 Request: used front brake pads (i'll pay shipping)
i know...what the hell kind of a request is this. well yes...if anyone has changed or is going to change their brake pads (even at the dealer)...can i have your old front pads...i don't care how worn the pads are.
feel free to PM me if this is something you're willing to donate...i'll pay for shipping obviously.
thank you.
Marco
thank you.
Marco
the fronts do not. the spring tensioner is attached to the pads. working with Carbotech, this is a big problem. the pads they sent me were too loose and started making noise. they sent me a revised set but it's the same thing. they can *try* to make it wider but they're concerned it'll just be an uphill battle.
an alternative solution they offered me was that if had a set of old pads, they'd sand it down and put their brake material on it...so i would always have the OEM-style base.
so far no other manufacturer has released pads for the f56. EBC has a part number but hasn't started production yet.
i threw the old pads out before realizing what they could have done. i have my parts guy on the look out for a used set. given what you want to upgrade to, may not be a bad idea to hold onto your set.
What compound Carbotechs are you using? All compounds expect the Bobcat squeak on the street regardless of spring tensioners. The squeak is because of the compound not being in the correct operating temp range causing the pads to squeal.
i did use disc brake quiet and on one side i used the blue stuff while the other side i used the red (CRC) stuff and the red stuff seemed to hold up better. after 2 weeks, the blue stuff had separated and melted away. the red stuff was still holding up. that was preventing the rattle.
i went back to OEM pads and a few days before my track events i'll just have to go to carbotech pads and then swap back when i'm done.
P.S. all of this is on the XP8's..
PelicanParts.com
Mar 29, 2016 02:48 PM
R50/53 Front Strut Mount Trouble
Mike Isaacson
Mar 29, 2016 07:58 AM
