F55/F56 Check Engine - P02A2
Old Oct 22, 2015 | 03:01 PM
Hi-De-Ho's Avatar
Hi-De-Ho
The check engine light in my 2015 F56 is lit - not flashing. The fault code is P02A2 (Cylinder 3 Balance – Fuel Trim at Max Limit).
Should I just erase the code and see if the fault goes away?
Should I limit my driving until I can schedule service?
Old Oct 23, 2015 | 04:40 AM
dirtyscarab's Avatar
dirtyscarab
Sounds like some sort of fuel injector failure. I would limit driving and call dealership asap.
Old Oct 28, 2015 | 05:22 PM
Hi-De-Ho's Avatar
Hi-De-Ho
I picked up the car from Mini service. They pulled a couple of codes of their own:
114301 - Fuel-Air mixture too lean cylinder 3
20A504 - Turbocharger coolant pump actuation - Line disconnection
After testing/inspecting a variety of things, they found that a connection was not making full contact with the coolant pump. They corrected the connection and cleared the faults - that cleared the check engine light and their test drive was normal.
Everything seems fine now.
rob&JCW
Oct 9, 2015 11:12 AM
eliseo1981
Sep 30, 2015 01:53 PM
CooperT
R60/R61 Stock Problems/Issues
Sep 22, 2015 12:54 PM
leonardogia
Sep 19, 2015 12:25 PM
