F55/F56 Code S554A
Old Jul 11, 2015 | 08:08 AM
kevinlhr310's Avatar
kevinlhr310
Code S554A
my MCS order was just produced and I had a look on BMW encoder out of curiosity.
Noticed that I have S544A (Geschwindigkeitsregelung mit Bremsfunkt. Cruise control with brake function).
I certainly did not order the Driving Assistant, nor do I see any other options that usually comes with the driving assistant.
Does anyone know if S554A is just the normal cruise control or the active one?
Old Jul 11, 2015 | 08:32 AM
Zillon's Avatar
Zillon
Do you have a VIN assigned yet? Let me know, I should be able to look it up.
Old Jul 11, 2015 | 08:34 AM
kevinlhr310
Yes, I looked up my Vin on BMW archives where I found that code.
Old Jul 11, 2015 | 10:20 AM
hammerhands's Avatar
hammerhands
S544A is the same number listed on my car, which is pretty basic.
I assume it means it will apply brakes if engine braking doesn't slow the car on a descent?
http://f30.bimmerpost.com/forums/sho...d.php?t=750134
From page 108 of the manual under Controls, Driving Comfort, Cruise Control, The Concept
http://www.miniusa.com/content/dam/m...al_Hardtop.pdf
The system brakes on downhill gradients if engine braking action is insufficient.
[Find a manual here: http://www.miniusa.com/content/miniu...-manuals.html]
Old Jul 11, 2015 | 10:21 AM
kevinlhr310
Sounds reasonable. Yea, probably it doesn't mean active cruise control.
Old Jul 11, 2015 | 10:44 AM
JMarkias's Avatar
JMarkias
That's the normal cruise control
My MINI has that option too (without the driving assistant active cruise control). Unlike older cars I've driven which increase speed when driving downhill in cruise control mode, the brakes are applied to maintain the set speed.
Old Jul 11, 2015 | 10:56 AM
siriuszero's Avatar
siriuszero
This is referring to Dynamic Cruise Control, which is standard on all F56/F55s.
When entering a curve or going down a hill with cruise control on, the car can actually apply the brakes for you to keep you at your set speed. It works pretty marvelously!
Old Jul 11, 2015 | 02:59 PM
watchluvr4ever's Avatar
watchluvr4ever
Originally Posted by siriuszero
This is referring to Dynamic Cruise Control, which is standard on all F56/F55s. When entering a curve or going down a hill with cruise control on, the car can actually apply the brakes for you to keep you at your set speed. It works pretty marvelously!
I'm really loving this feature on my new F56!
Old Jul 12, 2015 | 04:21 PM
maytulip32's Avatar
maytulip32
How long after production starts before you can look up your VIN? Mine started production on Weds 7/8.
Old Jul 13, 2015 | 09:47 AM
kevinlhr310
I got my VIN on July 7 and was able to look it up right away. Although prior to the car being completed you don't get any useful information. My car was finished on July 10 and all the technical information was available on that day.
Old Jul 13, 2015 | 02:53 PM
maytulip32's Avatar
maytulip32
What do you think it means that I can't see anything? Just says no info for this vehicle.
Old Jul 13, 2015 | 03:05 PM
kevinlhr310
maybe incorrect VIN? Production should only take 3 days?
Before production finished, my VIN gave the generic BMW info with a production date of 1973 or something similar.
Steffen.Johnson
71
Jan 26, 2021 09:11 AM
olson187
Sep 18, 2015 10:26 AM
Mini Hooper
Sep 17, 2015 01:58 PM
Enjoytheride
Sep 17, 2015 12:10 PM
