F55/F56 Tpms?
Old Aug 11, 2014 | 10:37 AM
Chazman's Avatar
Chazman
Tpms?
Now at about 2000 miles since purchased on 7/15.
Yesterday while driving in 90F weather the TPMS warning light suddenly came on the dash for tire pressure TOO LOW for the first time.
I checked the onboard dash reading and it indicates all 4 tires are at 36-37 psi range. I came home and again manually checked each tire using my own gauge and, indeed, they are all within 36-37 psi range. So, what the heck?
Anyway, went ahead and recalibrated/reset the TPMS by following the simple procedure on the dash menu followed by short driving as required. The TPMS warning light stayed OFF for now.
Any idea why the TPMS LOW pressure warning light came on when all 4 tire pressure readings are at the HIGHER end of the spec?
Old Aug 11, 2014 | 11:27 AM
papawhiskey's Avatar
papawhiskey
Did you check your tires at or just after delivery? I didn't but when I finally did (@2500) I found my tires were well below spec although the dash was reading them all much higher. As you did, I set them all with my gauge then ran the recal procedure. things are tracking well no (@5000). I think things are done at the factory and the dealers never check them. The whole ocean voyage bounces the cars around and maybe it messes things up.
Old Aug 11, 2014 | 11:46 AM
Chazman's Avatar
Chazman
You bet I did.
I checked tire pressure, coolant level, battery voltage, anything and everything under the hood as much as I could as soon as I got home - excpet the engine oil level because I couldn't find the damn oil dip stick! (well, had to rely on dash gauge).
Actually I raised the factory/deaelr set tire pressure from 32-33 to 36-37 psi the first day at home.
I just can't think of any reason why the TPMS would say "LOW" pressure when in fact it's at the "HIGH" end of the spec and after driving for 2000 miles with the same pressure reading.
Old Aug 11, 2014 | 02:39 PM
MasterYoda's Avatar
MasterYoda
You bet I did.
If you weren't yet aware, there is no oil dipstick. You have to check the oil level through the menu.
Old Aug 11, 2014 | 02:44 PM
Chazman's Avatar
Chazman
Yes, I figured that out the first day I brought the car home from my selling dealer.
That's why I wrote...
as soon as I got home....(well, had to rely on dash gauge).
Old Aug 11, 2014 | 02:59 PM
Mrdi's Avatar
Mrdi
Same thing happens to me in the MB.
Check the pressure, then re-set the TPMS.
Twice as much trouble for four times the expense.
Old Jul 13, 2015 | 03:29 PM
Melinda Willette's Avatar
Melinda Willette
Hello, have a 2006 Mini-Cooper S. Low tire pressure gauge has been lighted on dash for four months. Took to 2 foreign car mechanics - both said tire pressure fine. Both felt sensor shot. 1 quoted $250 to fix, other $65.00. Said no to both. Called Mini dealership and person said happens all the time. Gently pull out rubber rim around reset button and button near e-brake, disco from plug-in computer like plug. Remove piece and use rubbing alcohol gently while pushing button up and down. Dry off. Reconnect all. It worked immediately!!! Hope this helps with sticking reset button issue.
Old Jul 13, 2015 | 03:51 PM
TheBigNewt's Avatar
TheBigNewt
I realize we have different cars, and yours tells you the pressure mine doesn't. Mine tells me which tire is low. . It happened the other day, checked that tire it was 28 psi, added air and warning was gone, no reset needed. Maybe whatever tire it said was low has a bad sensor in it. I assume it said which tire.
freckles81
Jan 15, 2017 06:33 AM
OldElvis
Tires, Wheels, & Brakes
Oct 1, 2015 06:21 AM
Doc Pain
Sep 15, 2015 11:31 PM
PSU 98
Sep 11, 2015 11:20 AM
renchjeep
Sep 6, 2015 01:54 PM
