F55/F56 Observation: 2nd gear too low! (MT)
Shifting down into 2nd from 3rd, for a slow corner for example, seems to yield surprisingly high revs once in 2nd. The jump in revs for a 4th to 3rd downshift seems much less dramatic. If MINI ever consults with me, I'd recommend they take another look at their gear ratio selection.
Not that it's unlivable but it is a little annoying, as only the 3>2 downshift requires the extra caution.
Curious - anyone else notice this? Any work-arounds? Could I be mistaken?
I never noticed this but changing the ratio would hurt their 0-60 times. Just slow down a little more or install a power module and leave it in third at a higher speed.
...BTW, I happen to have a power module for sale!!
+1 its the rev matching in the higher gears. i actually like the 3/2 grabbing for decelleration.
It's up there kyoo - must be around 65. The F56 has the tallest 2nd of all three of the Gollums. I doubt I'll ever hit the limiter in this car on course, and certainly no course this year has gotten me close. Even the PCA and the National Tour courses which had many cars banging the limiter offered no challenge to my car.
If I am feeling cruel this afternoon I'll go measure it.
One of the charms!
Cheers,
Charlie
One of the charms!
Cheers,
Charlie
For the F56 MCS, assuming it actually revs to 6,500 RPM:
1st redline @ 32 MPH
2nd @ 59
3rd @ 91
4th @ 116
the rest is going to be drag limited.
Not sure on the Cooper ratios. FYI the JCW manual trans has a shorter 1st and 2nd, but the rest are taller.
The Cooper S has very similar top speed per gear in 1st through 5th as the Abarth, curiously enough. Versus the 86 twins, 3rd and up are taller in the MCS. They all need 3rd gear to hit 60 MPH though.
2nd @ 59
3rd @ 91
4th @ 116
Based on those MPH numbers, a downshift from 3rd to 2nd requires a lot more RPMs than downshifting from 4th to 3rd. That's why I think the 2nd gear ratio could be re-thought. Of course a 2nd to 1st downshift then would be even more dramatic - but who does that?
Personally, I live in Pittsburgh and the ratio for 2nd gear along with the low-end torque is great for climbing the hills in some of our residential areas. It's frustrating when you have to scream first, shift to second, and then you either don't have enough speed/torque or the engine is straining and you have to downshift to first which is always tricky.
I know you haven't mentioned it, but the R53 Getrag was IMO an outlier with it's acceleration-ruining tall 1st and 2nd. Looking at the ratio spread, be glad you don't have a JCW 6MT, as the ratios are even further apart in every gear. The BRZ has slightly closer ratios 1st to 5th, but then 6th is way out in left field tall. It really is amazing how close the MCS's 1st through 5th ratios are to the Abarth, they almost overlay. I DD an Abarth right now, and find the ratio spread totally average.
Remember...
They had to set the gears ratios for drivability... Folks do drive in bumper to bumper traffic...
They learned on the pre-refresh r53 (2002-2004) too tall a gear ratio can be terrible in traffic...they fixed it in 2005...
Bet they did not want a repeat...
One of the charms!
Cheers,
Charlie
One of the charms!
Cheers,
Charlie
That's the first time I have ever put that car on the limiter - it's nice and soft and not dramatic at all.
Cheers,
Charlie
R50/53 2002 R53 Creaking/Clacking
maestro39
Oct 27, 2015 02:38 PM
Aug 12, 2015 01:24 PM
