F55/F56 Plastidip
Old May 16, 2015 | 03:10 PM
clintmeister's Avatar
clintmeister
Plastidip
I plastidiped the chrome ring around the top of the car and it pulled off along with the tape I used to section it. The chrome trim on the grill seems to be maintaining. I thought this stuff would work.
Old May 17, 2015 | 06:23 AM
BoCRon's Avatar
BoCRon
I plastidipped the light rings on my R56 almost 4 years ago. Still looks good.
Did you get any pics of your process? I'm awaiting my VO/VO and the first thing I want to do is get rid of the belt line chrome. Most people I've seen just do the tape but I would love another option.
Annette
Old May 17, 2015 | 10:09 AM
clintmeister
The plastidip did not work on the belt line chrome. Very disappointed because I spent a lot of time taping off and covering the car. The chrome grill trim is working so far. As far as the headlights and tau lights rings, I bought the black ones from MINI. They were expensive but not a pain to have to worry about.
Old May 18, 2015 | 07:08 AM
Grizld700's Avatar
Grizld700
I've done the chrome line on several cars now. You have to make sure to pull the tape off when its wet, right after you spray the last coat. Pull at a sharp 90 degree angle and you should be ok. Also on the body side (under the chrome) it easier if you leave a 1" gap and just peal off when done, it will separate itself when pulling.
Old May 18, 2015 | 08:20 AM
clintmeister
Hmmm... I may have to retry that. How long does the plastidip hold up on the chrome ring?
Old May 18, 2015 | 08:21 AM
clintmeister
Here is the finished grill after the plastidip and clear coat!
Old May 18, 2015 | 08:24 AM
clintmeister
Another
Old May 18, 2015 | 08:34 AM
Grizld700's Avatar
Grizld700
So far mine has been on for about a year. There is only one spot where a rock hit last winter on the hood piece that has a chip. Easy enough to redo.
Also look into "Tape & Drape". Makes masking go waaaaaaaay faster.
Old May 18, 2015 | 12:55 PM
jeepndad's Avatar
jeepndad
When using plastidip if you wait until dry to pull off masking tape you will need to use a plastic sharp knife to cut the plastidip so not to pull off with the tape.
cawwwtun
May 3, 2016 08:03 AM
triple955
Sep 16, 2015 07:50 AM
nshannon29
Aug 25, 2015 10:42 AM
dmahoney12
General Mini related Ads
Mar 21, 2013 09:19 AM
Bmtespar
39
Oct 25, 2012 06:44 AM
