F55/F56 Stalling engine, restarting
Old Dec 23, 2014 | 12:18 PM
ce_npb's Avatar
ce_npb
While most won't admit it, I have stalled my car (MCS with manual trans) a couple of times. As anyone who drives a manual knows, this only happens when you've got someone right on your *** at a stop light. The restarting procedure doesn't appear to be quite a simple as putting the car in neutral and depressing the clutch (as it would with the auto start/stop feature). I guess the stall causes the car to have to be restarted via the start toggle. Anyone else have this experience? Ideally, I will never have it happen again, but...
Old Dec 23, 2014 | 01:51 PM
Crimguy's Avatar
Crimguy
You're right. No one will admit to stalling ;-)
I've stalled 2x, both from selecting 3rd instead of 1st. I depressed the clutch and hit the starter as you had to. This was working as expected, as far as I'm concerned.
Old Dec 30, 2014 | 03:21 AM
Kinetic89's Avatar
Kinetic89
I've stalled 3 times...but right before the engine completely dies, I push in the clutch in a last ditch effort to save myself from embarrassment.
I then hear the starter engage, and the engine starts itself like its waking up from a start/stop cycle.
No buttons have had to be pushed...always thought it was a bit odd, but cool.
Old Jan 5, 2015 | 10:57 PM
MadisonKobalt's Avatar
MadisonKobalt
Same experience as Kinetic89. First drive from the dealership in stop & go traffic. Quickly learned to check the gear indicator as I dropped it in. No problems since.
Old Jan 6, 2015 | 11:19 AM
JonCanada's Avatar
JonCanada
this happens if you have start/stop engaged - if you've turned start/stop off, you would need to press the ignition switch to turn the car back on.
when I first picked up my car - I was still experimenting with leaving start/stop on, and ended up shutting the car off as it turned on after stalling (the engine is just so damn quiet at idle); now I just leave start/stop off all the time - and if I stall, I would need to use the start/stop switch like a normal car.
Old Jan 6, 2015 | 11:36 AM
Kinetic89's Avatar
Kinetic89
Ah, that makes sense...its too cool to turn off though, for that reason now haha.
Old Jan 7, 2015 | 10:54 AM
SemperMini's Avatar
SemperMini
I will admit I have stalled it a couple times. The clutch pedal is REALLY light and springy, its hard to feel the clutch point until you have driven it a few miles and figured it out, so yeah, stalled a couple times first day. The start/stop function restarted the engine as Kinetic89 mentioned. I like the function. Makes a stall a lot less harmful on the ego when its right back on again lol
Old Jan 8, 2015 | 09:21 AM
George 2014's Avatar
George 2014
I don't stall the car very often but am glad that the speedo has a gear indicator. I shift into R rather than 1 semi-frequently. 10+ years of being used to a Honda gearbox.
R60abq
R60/R61 Stock Problems/Issues
Jun 6, 2017 05:15 PM
Markbett
Jul 3, 2016 04:28 PM
cornfly888
Aug 24, 2015 09:57 AM
Aug 21, 2015 10:07 AM
