F55/F56 Check Engine
Old Sep 10, 2014 | 10:34 AM
Mrdi's Avatar
Mrdi
Check Engine
2014 MCS Hardtop 1200 miles since new
Ck Engine light came on today.
Several restarts, no change
Checked gas cap, restart, no change.
No Recent refuel.
Any clues??
Apt at Dealer tomorrow for scan.
Old Sep 10, 2014 | 11:24 AM
Chazman's Avatar
Chazman
The other member had a Check Engine Light and, if my memory serves correctly, it was due to fuel evaporation system error. It was a defective sensor that sensed false fuel vapor leak from the evap system.
Let us know what you find out from the dealer.
If you want, you may just disconnect/reconnect the battery (-) terminal which should reset/turn off the light. However, that will not fix a problem if really exists, and the CEL would come on again. But if it was just one time fluke, it should remain turned off.
Old Sep 10, 2014 | 01:14 PM
Baseballpler's Avatar
Baseballpler
That would be me. Had the same issue, as chazman stated it was a sensor in the emissions system. Dealer took care of me, and gave me $500 in parts department credit for the troubles which I didn't even ask for nor expected ... Dunno if your car has the same issue but it would make sense. Mine occurred at 700 miles...
Old Sep 10, 2014 | 01:15 PM
Baseballpler
Delete
Old Sep 11, 2014 | 10:46 AM
Mrdi's Avatar
Mrdi
Check Engine light went off last night after about 8 starts during the day.
F56S delivered to Mini at 7AM. this morning
They want the car for the whole day, so I was given a Countryman S.
We'll see what code is stored.
We had run through a half tank of gas before the Ck Engine light went on.
Gas cap was secure when checked.
Old Sep 11, 2014 | 05:56 PM
Danger Dan's Avatar
Danger Dan
Wow!
Old Sep 12, 2014 | 11:18 AM
PresidioF56's Avatar
PresidioF56
Same thing happened to me. Brought it in and no codes. They simply updated the software and its been every since.
Would't worry about it.
Old Sep 12, 2014 | 11:54 AM
Mrdi's Avatar
Mrdi
From Dealer Printout :
Job #1) unfavorable DME programming as per SI M11 03 14
Found Fault code for oil pressure control
Programmed / coded with latest software update.
Test drove, operating as designed
Job #2) Journal Prefix IMCS ( I imagine this means record the job)
Comments welcome
rob&JCW
Feb 13, 2023 07:03 PM
R60abq
R60/R61 Stock Problems/Issues
Jun 6, 2017 05:15 PM
Mini Cooper r56 Pr
Aug 12, 2015 07:42 PM
truedrew
Aug 10, 2015 10:39 AM
Lt. Dan
Aug 10, 2015 08:23 AM
