F55/F56 Sports Mode Setup
Old Aug 10, 2014 | 08:11 AM
GregoryK's Avatar
GregoryK
Sports Mode Setup
I'm sure you have all played with this.
My questions is "Drivetrain". Besides changing the way the throttle reacts(becomes more sensitive) - I see no other difference in the standard transmission. Seems kind of lame.
I do like the drivers excitement display but wish you could customise it to show boost pressure and water temperature. Would be way more practical.
Old Aug 10, 2014 | 08:23 AM
lsmith42's Avatar
lsmith42
The steering is also tightened.
As for gauges, I've had good luck with an OBDII wifi interface and an app on my phone. More gauges than I would ever need!
Old Aug 10, 2014 | 08:56 AM
GregoryK's Avatar
GregoryK
ISmith. Isn't steering tightened in the Chassis mode?
I'll check OBDII...thanks.
Old Aug 10, 2014 | 10:23 AM
R99's Avatar
R99
Are you referring to simply switching the switch by the gear lever here?
Or are you saying that modes can be changed through the menu system on the screen?
Im confused?
Old Aug 10, 2014 | 10:40 AM
J_L's Avatar
J_L
Never heard of these- sounds very cool. Any particular model that's the one to get?
Old Aug 10, 2014 | 10:45 AM
GregoryK's Avatar
GregoryK
R99 ...sub-menu under settings.
Old Aug 10, 2014 | 10:51 AM
lsmith42's Avatar
lsmith42
On my F56, when I use the switch to change from mid to sport mode, it changes the throttle response and tightens the steering.
I don't have the big screen or dynamic suspension, so there may be other choices on those cars.
Old Aug 10, 2014 | 11:16 AM
R99's Avatar
R99
I can't find the sub menu you mention? can you post the steps to get to the menu?
Old Aug 10, 2014 | 11:59 AM
GregoryK's Avatar
GregoryK
*Settings
*Driving Mode
*Configure SPORT.
Hope this helps.
Old Aug 10, 2014 | 12:02 PM
R99's Avatar
R99
That menu is not present in my car, maybe it is not available for UK models?
Old Aug 10, 2014 | 03:31 PM
hammerhands's Avatar
hammerhands
I've just bought a GoPoint BT1 from eBay, Bluetooth and works with Apple, from Richmond, BC.
Old Aug 10, 2014 | 03:51 PM
russmini's Avatar
russmini
*Settings
*Driving Mode
*Configure SPORT.
Hope this helps.
Driving mode not present on my non-S. Doesn't seem to appear in the manual as well.
Old Aug 10, 2014 | 04:34 PM
hammerhands
It's on page 108.
It says there are 4 ways to set the driving modes.
Old Aug 10, 2014 | 05:10 PM
R99's Avatar
R99
100% not there in the menu system on my car (Cooper S).
Its a UK spec car though, so that may explain things?
Old Aug 10, 2014 | 08:14 PM
tuco44's Avatar
tuco44
*Settings
*Driving Mode
*Configure SPORT.
Hope this helps.
Same on my S.
To elaborate - under "configure SPORT" you can select one of: Drivetrain/Chassis/Drivetrain&Chassis.
Old Aug 11, 2014 | 05:27 AM
CobraBob's Avatar
CobraBob
I believe it changes more than throttle response and steering. I have to believe that it changes fuel delivery and maybe even turbo boost as well. Yes, throttle response is definitely heightened, but WOT runs from a start in the three modes feels very different. In Green mode, WOT from 1st gear feels like I lost 2 cylinders or most boost. Darn right horrible. Mid mode is a compromise that feels like some power has been lost. Beyond throttle tip in. Sport mode gives me what I wanted from my MINI S to begin with. Sharp throttle response and full-on power through the RPM range. I would love to know exactly what changes are made with the computer in Green, Mid and Sport modes. I just have to believe that if you put this car on a dyno, and did 3 pulls (Green, Mid and Sport), you'd see a big difference in fwhp and torque between Green and Sport.
Old Aug 11, 2014 | 05:53 AM
champ198's Avatar
champ198
In addition to the throttle sensitivity, I have noticed that when accelerating and letting off the gas, the car keeps the lower gear slightly longer. I believe the shift points are changed when the car is put in "sport" mode from "mid" mode. I rarely use sport mode anymore, mainly mid and green.
Old Aug 11, 2014 | 06:14 AM
George 2014's Avatar
George 2014
Originally Posted by CobraBob
....I have to believe that it changes fuel delivery and maybe even turbo boost as well... I would love to know exactly what changes are made with the computer in Green, Mid and Sport modes. I just have to believe that if you put this car on a dyno, and did 3 pulls (Green, Mid and Sport), you'd see a big difference in fwhp and torque between Green and Sport.
+1
The first thing I noticed about "Sport" mode when we initially test drove one of these was the exhaust popping on the downshifts. That means the ECU has disabled overrunning fuel cutoff and is allowing unburned fuel into the exhaust manifold (unless the sound is fake and actually made up in the head unit, LOL...) The adviser made a point to mention to ask me to listen for this sound, so I guess they are trying to impress people with it. Personally, I just keep the car in Mid mode most of the time.
Anyone out there got an buetooth OBDII setup for their smartphone yet? We could learn a lot by looking at A/F ratios, boost level, and ignition timing between the three modes.
Old Aug 11, 2014 | 12:01 PM
allhailpoptart's Avatar
allhailpoptart
I use
this BT adapter this BT adapter
from Amazon along with the Torque Pro Android app - https://play.google.com/store/apps/details?id=org.prowl.torque
I've used this setup in a 2003 Audi A4 turbo, a 2013 WRX and soon to be my 2015 Justa. It's worked well on everything so far. Gauges galore and it hooks into a lot more than you'd expect.
Old Aug 13, 2014 | 01:23 AM
Girl from Oz's Avatar
Girl from Oz
Has anyone tried launch control yet?
Old Aug 13, 2014 | 04:32 AM
GregoryK's Avatar
GregoryK
BOB..Well checked mine again last night. Just the throttle reside it's changed. My steering dies not tighten. There is fine difference I sound but that seems to come from the noisemaker. My steering it's tightened only when chassis is activated as part of the sport submenu.
Old Aug 13, 2014 | 07:27 AM
J_L's Avatar
J_L
I have an S with manual trans, with the basic orange screen, with sport suspension, in the US. I don't see that menu. I do have an item at the bottom that says "configure green," but nothing about sport. I guess because I have nothing else to adjust- no auto trans or dynamic suspension?
Old Aug 17, 2014 | 03:31 PM
ThumperMCS's Avatar
ThumperMCS
All of the above is true.
They run different engine mapping (afr, timing, boost, etc) between all 3 modes. It is NOT just adjusting throttle sensitivity like the Sport button on the R56
1/4 mi & 0-60 times are completely different between the 3 modes as a result
Old Aug 17, 2014 | 05:17 PM
GregoryK's Avatar
GregoryK
Does not feel like that to me. Pops are from the interior speakers..
Here's a quote from the "Motoring File Review"
"MINI’s new driving modes are a significant update to the car. Sport Mode made huge improvement over the previous sport button. The system now adjusts three things: throttle mapping, steering weight and suspension firmness in cars with the variable dampers. It’s also lightly configurable, with drivers able to select the suspension settings separate from the Sport Mode throttle mapping and steering weight. You cannot, however, turn on Sport Mode and then turn off the extra steering weight that is programmed in. You also can’t select the firmer “Sport” suspension dampening in Green mode, which is unfortunate. All that said, the big take-away for me was that at least the firmer steering of the sport mode doesn’t blunt the feedback through the wheel like the previous system did."
What he says feels right by my driving this car.. Hey maybe we are wrong just his and my opinion. :-)
Old Aug 17, 2014 | 08:02 PM
ThumperMCS's Avatar
ThumperMCS
So you are telling me you think Green mode feels identical to Sport mode when you go WOT?
You can feel it holding back boost in Green, pretty apparent too...
The pops in sport mode are not from the speakers...listen to one from the outside, that is one piece of the sound engineering that is organic
