F55/F56 AC always on when turn on the engine?
Old Jun 13, 2014 | 07:51 AM
  #26
Rhino6207's Avatar
Rhino6207
Originally Posted by GT350
I have auto climate control off, but the fan turn on every time, the auto climate control is still off. I may give the dealship a call if i cannot figure this out.
I have Auto Climate Control and the same problem. I tried shutting everything off (auto function, fan, etc.), checking to make sure my profile was selected, turned off the engine, locked with the fob. I then walked away for 5 minutes, came back and unlocked with the fob, started the engine and low and behold....it did it again!
Does the same with my wife's fob as well. Please post what you have found out from the dealer.
Old Jun 13, 2014 | 08:18 AM
  #27
mbatech's Avatar
mbatech
I am having the same problem everyone has described here. Can't get the AC and Vent fans to stay permanently off when turning off everything before shutting off the car. Anyway have any feedback from their MA? I'm contacting mine today. Thanks.
Old Jun 13, 2014 | 12:05 PM
  #28
TheBigNewt's Avatar
TheBigNewt
Good reason to not get the Auto Climate Control With my R56 everything stayed the same when you shut off the car.
Old Jun 28, 2014 | 02:28 AM
  #29
mkskchun85's Avatar
mkskchun85
Maybe 75% of the time here's how i got it to not turn on:
1) Turn off the climate (all off) and drive for approximately 1 minute
2) power lever off x2 to turn the car off
3) when i come back, AC was not on
Old Nov 26, 2014 | 09:47 AM
  #30
hp79's Avatar
hp79
Mine turns on too. 2015 F56 comes with auto climate control stock.
It's annoying that AC and the fan turns on by itself every time I turn on the car. I use AC maybe couple times in a month just to defog because I don't like mold growing in the condenser.
edit:
I don't know how, but my AC didn't turn on for the whole day today during several shopping trips. I almost thought maybe I blew the AC fuse while installing my dash cam last night, but when inside started getting foggy I turned on my AC with no problems.
So maybe it depends on which remote you have? Thinking back, I had both in the car the first day.
Old Nov 27, 2014 | 09:26 AM
  #31
r33's Avatar
r33
It should be code-able.
I able to code them for all F-series BMW cars.
If any of you in So.Cal area, PM me and let's do some coding.
Old Nov 27, 2014 | 10:15 AM
  #32
hp79's Avatar
hp79
This is really annoying.
I'll have to order the OBD-ethernet cable then to start looking into it. I saw it was around $5 or so. It's actually a simple wiring so...
Old Nov 27, 2014 | 11:12 AM
  #33
MyOrangeOne's Avatar
MyOrangeOne
If my AC is so ff when I turn off the engine, it does not come on when I later start the engine. I have auto AC.
Old Nov 27, 2014 | 11:16 AM
  #34
DarkBlue15MCS's Avatar
DarkBlue15MCS
Originally Posted by hp79
This is really annoying. I'll have to order the OBD-ethernet cable then to start looking into it. I saw it was around $5 or so. It's actually a simple wiring so...
From what I've read some work some don't. I paid $20 for my cable
Old Nov 28, 2014 | 08:17 AM
  #35
GregoryK's Avatar
GregoryK
I have the same issue with the recycle. Mine used to remember the setting. Took the car in for a fault light. They reset the system and not it doesn't remember. Very annoying.
09R56
Nov 16, 2022 10:49 AM
patrioticmini
Aug 20, 2015 10:54 AM
tylewis
Aug 18, 2015 06:53 AM
Mini Cooper r56 Pr
Aug 12, 2015 07:42 PM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
