F55/F56 Using Bigger Wheels on the F56
Old May 22, 2014 | 09:36 AM
  #26
MINIAC's Avatar
MINIAC
Originally Posted by GregoryK
Not following your logic mate. Putting slightly bigger ties on the rims will make them look bigger....because they will be bigger.
The wheel gap is black and tires are black. The only way to get to bigger looking wheels is to fit larger wheels. If you're running black wheels it won't make that much of a difference.
Old May 22, 2014 | 09:54 AM
  #27
torpeau's Avatar
torpeau
The gap, the tires and often the wheels are black, so I doubt if many people see a problem. With non-black (white, silver) wheels, the differences are much more noticeable to me -- bigger is better, up to a point.
Old May 22, 2014 | 10:40 AM
  #28
GregoryK's Avatar
GregoryK
My R56 with 17" rims and 205/45's
New F56 with 17" rims and 205 45's
Problem is clearly visible and I thinking that lowering the car will not change the front and back gap.
Sorry I know the first photo is a bit dark!
Attached Thumbnails Using Bigger Wheels on the F56-dsc02056.jpg   Using Bigger Wheels on the F56-dsc02234.jpg
Old May 22, 2014 | 07:27 PM
  #29
champ198's Avatar
champ198
Oh yeah, I see exactly what you mean.
Old May 22, 2014 | 08:43 PM
  #30
ZIPPY "S"'s Avatar
ZIPPY "S"
GregoryK, I totally see what you mean also. The wheel well opening is a tad larger then the R56. Along with that the nose also over hangs the front wheels a tad more also. With those things it makes the wheel appear smaller. But here is where im sure some wont agree with me. I wouldn't just put taller tires on it to make up the difference. I think that might give you the look of to much tire. I would go with larger wheels. Something like 18" and go from there. You want to try to make it all look proportionate to the car. Im a wheel guy. so I would at least go with 18". Heck I even had them on my R53. Cheers my friend!
Old May 23, 2014 | 04:17 AM
  #31
R99's Avatar
R99
The answer is larger rims and lowering.
Old May 23, 2014 | 07:35 AM
  #32
MINI #1's Avatar
MINI #1
After you get your larger rims...save some more money for another set of larger rims...
Geographical location dictates what I use for rims and tires.
Old May 23, 2014 | 07:41 AM
  #33
MINI #1's Avatar
MINI #1
I tried running 17's in NJ and it doesn't work...because of the geographical location, I also can't put the JCW body kit...however if I lived in SC...I would run the 17's and a body kit.
I went with 16's with bigger offset non-runflat tires and that works well...
Old May 23, 2014 | 07:45 AM
  #34
GregoryK's Avatar
GregoryK
Mini #1. Are you saying because of snow? or pot holes. I'm in Toronto and we have both. Ran 17" 215 45's winter and summers and all-seasons. All were fine but you have to watch the unplowed lanes!
Old May 23, 2014 | 07:50 AM
  #35
MINI #1's Avatar
MINI #1
Potholes, Bridge Construction, different grades of road surface, gravel, etc.
I would go with bigger non-runflat tires first
Old May 25, 2014 | 06:50 AM
  #36
tigerhonaker's Avatar
tigerhonaker
I make no bones about the fact that I think the wheels look too small. They have increased the size of the car and not the wheels. Even if you lower this car the gap will still be there front and back of the wheel. Most people naturally photograph their New F56's from front and back because those are the best angles but at some angles it does not look so good. The big gap shows off the large overhang too.
So what if you put on 18' rims with 215/45 R18 tires.
Might look good but would give the wheels a bigger diameter. It would likely throw off the speedo and mileage calculations...but there may be a way to adjust those.... They would be quieter and smoother at speed...
Might look mean. Any thoughts??
In my case I simply ordered the optional 18" wheels and tires from Mini.
They look just fine to me on my MCS but as always that is just my opinion.
Terry
Old Jun 9, 2014 | 06:27 PM
  #37
GregoryK's Avatar
GregoryK
So ended up getting 18" Rims and 215 40 18" tires...I posted some pics here.
https://www.northamericanmotoring.co...wheel-gap.html
Thanks for your feedback and ideas.
Greg
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
jcb-memphis
Aug 8, 2015 11:09 AM
Aug 5, 2015 02:11 PM
Aug 5, 2015 02:10 PM
