F55/F56/F57 Stock Problems/Issues Discussions related to warranty related issues and repairs, or other problems with the OEM parts and software for F55/F56 MINI Cooper AND Cooper S models.
B46 Motor stutter
Old Sep 29, 2020 | 10:39 PM
Smvckerz's Avatar
Smvckerz
Question B46 Motor stutter
Hello mini enthusiasts, i am here to bring you guys an issue i encountered with my 2015 mini cooper s f56. I had finished working out, leaving the field and starting my car, but when i started my car after 2 seconds, the car sounded like it wanted to die and the RPM's were kind of going crazy (staying between 1,000 to 1.5k but going back and forth) but it was stuttering and i gave it some gas, and it went away. Any ideas as to what this could be? This wouldn't be the first time it happens. It happens every couple of months or so. But i've ignored up until now because it is starting to worry me a little bit as this is my daily driver and only car i have. So id like to get to the root of the issue before something major happens and catch it just in time. Any help would be appreciated. Thank you!
Old Sep 30, 2020 | 04:01 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
First off, any modifications to the car? Are you up to date on maintenance?
Old Sep 30, 2020 | 04:05 AM
Smvckerz's Avatar
Smvckerz
hello, and no. No modifications whatsoever. Bone stock. And yes. Have given its regular oil change when needed. Spark plugs will be changed very soon. Coil packs as well. So yes, everything has been up to date so far.
Old Sep 30, 2020 | 04:12 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
I would start with plugs and coils, and see if that helps. If no change, my next thought would be MAF sensor.
Old Sep 30, 2020 | 01:18 PM
Smvckerz's Avatar
Smvckerz
ok, sounds like a good plan. How could I tell if the MAF is bad or needs to be replaced?
Old Sep 30, 2020 | 01:27 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Read the comments in the "Product Details" section here:
https://www.ecstuning.com/b-bosch-pa...627602038~bos/
Old Sep 30, 2020 | 04:06 PM
Smvckerz's Avatar
Smvckerz
Just read them. Will be trying out both of your suggestions. Thank you!
EnchiladaJones
Aug 12, 2020 01:59 PM
atlantaorange
Nov 15, 2016 09:34 PM
twentytwo
Feb 6, 2016 10:16 AM
hp79
Jul 13, 2015 09:53 AM
ilikeben
Sep 25, 2014 12:41 PM
