F55/F56/F57 Stock Problems/Issues Discussions related to warranty related issues and repairs, or other problems with the OEM parts and software for F55/F56 MINI Cooper AND Cooper S models.
Stripped oil pan bolt thread
Old Feb 20, 2019 | 05:31 PM
spotted's Avatar
spotted
Has anyone ran into when the thread for the oil pan bolt was stripped?
Was doing the oil change and I noticed when I was taking off the oil pan bolt that there was metal within the threads of the bolt. Looked in the hole and there's no thread inside for the bolt to catch on.
Not fun.
Looking online trying to find a solution but not really getting much. I saw a oversized bolt but not sure if you get the original size or the next size up.
Then there's also a thing called ecobolt, which is an oversize bolt but you leave it in there.
Out of warranty so not sure what to do next.
Old Feb 20, 2019 | 06:28 PM
N0B0DY's Avatar
N0B0DY
You could try the oversized bolt but if you arne't comfortable with that you can always replace the oil pan.
Old Feb 20, 2019 | 10:10 PM
spotted's Avatar
spotted
Going to try the eco-plug. Hopefully it works. Seems to have positive reviews.
Old Jul 8, 2023 | 05:55 PM
minigirl78's Avatar
minigirl78
Wondering if you had success with the eco-plug? I've run into the same situation and need to find a solution...TIA
Old Jul 9, 2023 | 06:12 AM
spotted's Avatar
spotted
Well I did one thing for a while. I used one of those plus where when you screw it, it expands to fill the plug. This what I used: Dorman 65200 Oil Drain Plug Universal 1/2 In. Can get it at O'Reily's or on Amazon.
But then I ended up just rethreading it with this kit: TIME-SERT M12 X 1.50 Metric Drain Plug Repair Kit. Here it is on Amazon:
https://www.amazon.com/gp/product/B003SER3PA/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B003SER3PA/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
It was nerve raking while doing it. But I've had it for over 3 years, and it's been fine.
I also got the Stahlbus Oil Drain Valve - M12x1.5x12mm so I wouldn't have to keep on changing the oil pan bolt.
Old Jul 9, 2023 | 06:51 AM
minimusings's Avatar
minimusings
Some good solutions above, my question is who stripped it, have you been doing the oil changes?
Old Jul 9, 2023 | 10:29 AM
cargusjoh's Avatar
cargusjoh
The MINI dealership has a special tool/kit that drills out the hole collecting most of the debris, then has a one size up plug. Might be work the $$ to have them do it.
Old Jul 9, 2023 | 10:44 AM
spotted's Avatar
spotted
Was a shop. Didn't have my jack with me to do it myself. Didn't notice it was stripped til I did the following change.
Old Jul 9, 2023 | 01:26 PM
cjv2's Avatar
cjv2
But then I ended up just rethreading it with this kit: TIME-SERT M12 X 1.50 Metric Drain Plug Repair Kit. Here it is on Amazon: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1.
Good stuff in this post. Thank you for the detail.
whitenight
Sep 1, 2009 05:15 PM
mini&m3
Sep 28, 2008 01:17 PM
Glenns0245
Apr 8, 2007 05:27 PM
MINIKB
Mar 11, 2006 01:56 PM
